DR-HD100 720p60 at DVinfo.net
Old February 5th, 2008, 07:08 AM   #1
DR-HD100 720p60
does anyone know when firestore will be releasing the version 3.0 update to record 720p60 in quicktime format? I have waited a whole 3 weeks for the update to come out, but without any luck....Firestore said they would release it in mid-Jan '08....I have even emailed the support team, but I haven't had a response from them...
Akbar Ukani is offline   Reply With Quote
Old February 6th, 2008, 07:25 AM   #2
Honestly, the company seems to be in a bit of organizational disarray. JVC reps at a trade demo talked extensively about this workflow, and promised it well before the end of the year. It was conditional on first getting the FCP upgrade for 60p/50p native editing, but they said it was an easy step from there that would be about 2 weeks....
I did after some trouble get a rep in service to call me before xmas, and they didn't even know about the process - they asked someone else to merely dig up the same press release you saw. The website has lots of outdated info. Meanwhile, the FS-4 has a large rebate - The DR-HD needs a price break even more!
The units are great when they work, but we have one disabled unit at a production company I work with. Hope that can be resolved.
Sean Adair - NYC - www.adairproductions.com
JVC GY-HM-700 with 17x5 lens, MacPro 3.2ghz 8-core, 18gb. (JVC HD200 4 sale soon)
Sean Adair is offline   Reply With Quote
Old February 7th, 2008, 05:48 AM   #3
im waiting for 50p in quicktime format too.
Javier Tabares is offline   Reply With Quote
Old February 7th, 2008, 06:41 AM   #4
Akbar,
can the firestore change its frame rate same time you change the camera frame rate? Or do you have to independently set this on the firestore?
I'm looking forward to this solution but don't know much about the firestore.
Ted
Old February 8th, 2008, 02:10 PM   #5
Originally Posted by Ted Ramasola View Post
Akbar,
Ted
Hi Ted...The firestore automatically recognizes the frame rate that you set within your camera...720p30...720p24...etc....I have the firestore actually hooked up as a "syncro slave"...As a matter of fact, I have even tried setting the camera to record in 720p60 and when I try recording it the firestore drive shows an error when set to record in Quicktime Format...It will record if the HDV format is set to m2t........The only thing you will have to change when recording is whether you want the firestore to record in "DV" or "HDV"..Its quite simple If you ask me....If you select "DV"...you will see different options such as your options for Recording format will be different (raw dv, quicktime, quicktime 24p, avi...)...HDV will give you 2 options (m2t, quicktime)....hope this answers your question
Old February 9th, 2008, 01:44 AM   #6
Thanks for your reply Akbar
Thats exactly what i wanted to know.
Ted
Ted Ramasola is offline   Reply
