FUJINON TH13X3.5BRMU better in low light? at DVinfo.net
Old January 29th, 2008, 03:29 PM   #1
Hi all,
This is my first post. I'm glad to have found this forum.
I've been disappointed with my HD110's performance in low light (was using a PD170, which is amazing in low light).
So, does the 13X Fujinon lens improve low light performance?
thanks,
Jay
Jay Rosenstein is offline   Reply With Quote
Old January 29th, 2008, 04:10 PM   #2
I think low light performance is a factor of the pixel size on the sensor... With a 1/3" CCD, and HD, the pixels get pretty small... The PD170 has much larger pixels by comparison... One of the "limitations" of HD (it is actually a trade-off)... That said theother lens may have a bigger maximum apture size - which could allow for more light to hit the sensors (the original is 1.4), though I doubt that...
Maxene Kuek is offline   Reply With Quote
Old January 29th, 2008, 04:53 PM   #3
Jay, go into the sticky scene files (that sounds horrible) for the HD100s. Tim Dashwood has a low light setting that really helps you see in the dark without the grain. Good luck
Eric Gulbransen is offline   Reply With Quote
Old January 29th, 2008, 07:07 PM   #4
I should clarify that I'm talking about SD performance only right now.
Old January 29th, 2008, 07:15 PM   #5
Shooting SD does not affect the pixel size which is what most determines lowlight performance...
Old January 31st, 2008, 05:20 PM   #6
Jay, we did some low-light, high-contrast tests on our 251 with mini-35 and cine high-speed primes, I think T 1.2 max aperture. Amazing camera performance !!!
But even more amazing: the scene file that did the best job was superwide, followed by bleach-bypass, not low-light as one would have expected.
yes, doing tests and getting the right settings/scene files is crucial.
and the standard 16x5.5 lens didn't behave that poorly, either. not to be compared to the cine glass but still astonishing.
the right setting/scene file is more important than the lens (not considering depth-of-field, flaring, distortion etc).
test them all on your actual sets, the take a really good monitor (SD in your case, like a 21 inch Sony or JVC broadcast) and compare carefully.
Claude Mangold is offline   Reply
