Fast-forward going turbo at DVinfo.net
Old January 15th, 2008, 06:54 PM   #1
Something has happend with my HD100.
When i use fast-forward it goes up to an extra high speed and just continue without decelerating at the end of the tape. This is cousing me big problems when capturing because it goes so fast it stops to read the timecode and therefore ignore all the logging being made. Funny, is it not! Rewinding works as normal tough.
Anyone ho hade the same problem or that can give me a hint of what could be wrong here?
Mikael Widerberg is offline   Reply With Quote
Old January 16th, 2008, 10:05 AM   #2
Hi Mikael,
I'm not 100% clear. If you select fast-forward on the camera's deck controls or remotely through the capturing computer, it should ramp up to a high speed and keep going to the end (or you hit stop).
Are you getting this response when the editor is trying to capture a set of logged clips automatically? If so, what system?
It could also be problems with a particular tape, or broken timecode, that can cause strange symptoms with capture. Have you tried an older tape that you know worked as expected before?
Sean Adair - NYC - www.adairproductions.com
JVC GY-HM-700 with 17x5 lens, MacPro 3.2ghz 8-core, 18gb. (JVC HD200 4 sale soon)
Sean Adair is offline   Reply With Quote
Old January 16th, 2008, 03:55 PM   #3
Yes, but it seams to go a lot faster then before (ultra high speed or something, its like a Ferrari), and also, it do not slow down just before the end of the tape.
It must slow down before the tape ends, athervise it can broke the tape. If I go for say 3x fast-forward. then everythings is okay, and the timecode is present.
Its not a problem with a particular tape, its the same no mather with tape, new or old used ones. Its a problem with the camera itself. As soon as I hit the FF botton, the timecode frezzes and letters telling me minits left on the tape go sero.
Old January 16th, 2008, 06:22 PM   #4
Images: 18
Hi Mikael..........
Don't know anything about the HD100 but it sounds like a sick puppy to me.
How hard is it to get in touch wth your nearest JVC authorised repairer?
That would be my first move.
CS
Old January 17th, 2008, 04:52 AM   #5
CS
Puppy it is.
Yes you are right, the best would be to contact my local rep. Im afraid tough that there are so many faults on this cam (SSE and sometimes blue screen) that it would coast to much to repair it. My tactic for now is to just keep it alive.
