Camera crash during firmware update! at DVinfo.net
Old October 15th, 2007, 04:22 PM   #1
OOOOPS! I accidently powered off my camera while doing a firmware update and now my camera won't turn on properly. What a moron I am! Anyway, can anyone out there let me know if there is a trick to reseting the camera(GY-HD100)back to factory settings so I can try this again or does it have to go into JVC now?
Scott Harper is offline   Reply With Quote
Old October 16th, 2007, 02:11 AM   #2
There was another guy a while back that powered down the camera before the update took. He had to send it to JVC to get it fixed.
You must wait about 6 minutes and for the audio LED's to blink unisen at 1 sec intervals to know the update is complete. Pull out the SD card and the camera reboots itself.
Lesson learned, don't update the firmware unless you need to. If you are not having the FCP split clip problem during capture, don't update the camera. It's too risky.
Scott Jaco is offline   Reply With Quote
Old October 16th, 2007, 05:09 AM   #3
WARNING Tape chewed during update
When an HD201 sequence would not play back (see separate post on HD201 today), JVC in London recommended updating two of the firmware modules, which I duly did successfully and with great care, reading the instructions all through before starting. What was not in them and what I stupidly omitted to do was remove the tape first. At some point during the process the tape door opened, sadly without unthreading first, so the faulty recording was also physically damaged. Luckily it was sitting in the fault area so no more was lost - but spooling by hand is such a bore.
Richard Jolly is offline   Reply With Quote
Old October 16th, 2007, 07:54 AM   #4
Originally Posted by Richard Jolly View Post
...reading the instructions all through before starting. What was not in them and what I stupidly omitted to do was remove the tape first.
When I got an email upgrade last week, the JVC UK guy told me specifically not to leave a tape in the machine. Maybe its as a result of hearing about problems like the one you had, so at least they're updating their instructions when they find out about a potential problem
Paul Jefferies is offline   Reply With Quote
Old October 16th, 2007, 08:31 AM   #5
Just talked to JVC and they told me that there is a good chance that I have to toss the camera. Can you believe it! Who would have thought that a simple thing like this would smoke the entire camera. Boy, what an expensive lesson learned. Anyone out there who is thinking of updating firmware on their own better make sure you follow the instructions to the T, not like the moron who's now out 6k.
Old October 16th, 2007, 01:26 PM   #6
I can't believe it
JVC can usually recover a camera that has corrupted firmware, but you will have to send it to them to get it done, and there might be charges involved. I would guess someone at JVC has a twisted sense of humor if they told you you'll have to trash your camera, and meant it. Didn't you hear the laughing in the background?
Robert Yarosh is offline   Reply With Quote
Old October 16th, 2007, 03:08 PM   #7
Wow! I can't believe that you could toast a camera by messing up a firmware update. Even having to send it to JVC for repair sounds unbelieveble.
We make tape libraries for computers, not cameras, but I can assure you that we spend days if not weeks trying every way we can to screw up a firmware upgrade and if we succeed, nothing ships until it gets fixed. There is no excuse in this day and age for any type of product whatsoever to need any more than a power on reset regardless of how hard the user tries to screw up a firmware update. This is about the most fundamental concept there is.
Old October 16th, 2007, 04:44 PM   #8
True dat, baby! It makes absolutely no sense. Can you imagine having to throw out your computer because you screwed up your software download!
Old October 16th, 2007, 04:49 PM   #9
Trust me Robert, there's no laughing going on here. He's the head tech there and he said he's already seen it happen a few times before and the only possitive sign in my case, if there is one, is that my tape door still opens- which, he says, shows some sign that the CPU is still talking to the camera. But he still reiterated "Don't get your hopes up."
Old October 16th, 2007, 09:06 PM   #10
It's equally inconceivable that they couldn't just replace the CPU - after all, they have to install a CPU when they build the camera. It doesn't mysteriously grow in there like the human brain - it's a part that someone installs.
Even if the user doesn't power down during a firmware update there's always the possibility that power (battery or AC) could fail during an update. Not covering this possibility is defective engineering, pure and simple.
Old October 16th, 2007, 09:10 PM   #11
Couldn't agree more, Jim. If I'm going down on this one with my own dime, it's kickin' and screamin' the whole way!
Old October 16th, 2007, 11:00 PM   #12
I had no idea you could actually permanently damage the HD100 in this fashion.
I guess I'm really lucky my upgrade went OK. Still, I should have used a battery instead of the AC adapter in case of a power failure.
If it's this dangerous, JVC should not be allowing consumers to do their own upgrades. This is completely insane!
I remember flashing the BIOS on my desktop computer with a new version but it didn't take for some reason. I was able to go to another computer, download the old version, put it on a floppy boot disk and re-flash the bios, thus saving me from buying a new motherboard.
It's just software. Granted, it may require a tech to get into the guts of the camera to do it, there is just no excuse for JVC to tell you that you've just made a 5K paperweight!
Do you have equipment insurance for your gear? I would suggest using it.
Old October 17th, 2007, 06:34 AM   #13
First of all, this is almost to hard to believe!
I think I would of started laughing at the tech.
This is the most rediculous thing i've ever heard.
Why can't he reset to put the system into a ready state for download?
If it will not do this via software, everything I ever worked on was able to via dipswitch or jumping connections.
OK, if he can't manage that simple task, how about replacing the component PCB at fault?
I'm sorry but I work with this type of stuff for a living.....but junk the whole camera.....oh please............
Steven Thomas is offline   Reply
