Wide Angle Lense for GY-HD100U at DVinfo.net
Old October 1st, 2007, 03:12 PM   #1
Can someone tell me an inexpensive wide angle lense for the GY-HD100 and approximate price I'm looking at?
Lisa
Lisa Bennett is offline   Reply With Quote
Old October 1st, 2007, 03:29 PM   #2
Lisa
Inexpensive as in $6,599? Fujinon 13x. Or where you thinking a $199 screw on adapter?
Old October 1st, 2007, 04:20 PM   #3
Hi Alex,
Actually, if there is a screw on adapter that would work with my hd100u lense, then for this one project, it would work.
Lisa
Old October 1st, 2007, 04:51 PM   #4
BHphotovideo (one of many reputable online places) has a Cavision 82mm screw in type for $199.
They also have the JVC 0.82x Zoom Through Wide Angle Converter Lens for Fujinon TH16x5.5BRMU Lens for $509.
Never seen either one in person, but I trust the JVC one more. But if it's only a couple shots, then it doesn't matter too much.
......maybe try local phtogoraphy shops and look for a wide angle adapter/filter for 82mm or lrager (difficult, most will be 52mm for 35mm style lenses) but you might luck out.
Better idea.........If it's a short duration, maybe check into renting at far better 13x Fujinon lens (super wide) for the weekend for $150 - $200 or so. The 13x Fujinon lens is better than the stock lens and adapterand would ever dream of being.
Old October 2nd, 2007, 02:51 PM   #5
Century Optics / Schneider have a .7 or .7/.5 for the Fujinon 16 X. A little more expensive but good quality.
http://www.schneideroptics.com/ecomm...=1085&IID=1362
Phil Balsdon
Phil Balsdon is offline   Reply With Quote
Old October 2nd, 2007, 02:57 PM   #6
Thanks for the guidance on this. Since it's only a couple of shots I think the adapter/filter version will work out.
I'll check into what I can find.
Thank you
Lisa
Old October 2nd, 2007, 05:58 PM   #7
I've got the .82 jvc adapter.
It's pretty rare that i ever take it off.
Highly recommended.
~~~Adam Oas~~~
www.TexasMotorSpeedway.com
Adam Oas is offline   Reply
