power cable question at DVinfo.net
Old September 26th, 2007, 06:31 PM   #1
Hi,
I have an IDX adaptor on the back of my HD101, and I recently purchased a power lead to go from the 2 pin socket on the adaptor (is it called the D- tap?) to a monitor. I plugged the lead into the IDX adaptor, however now I can't get it off! Is there a knack with these things on how to disconnect them or am I just being stupid - I am reluctant to pull too hard... any help appreciated...
Paul Jefferies is offline   Reply With Quote
Old September 27th, 2007, 10:28 AM   #2
Hi,
you should really use only your strength to pull it out.
everything new, I had with d-tap was fistly really hard to pull out, seemed nearly impossible. But after several uses it became much better, normal.
so I think you can get it out normaly, but for the first time it seems impossible.
Petr Bastar is offline   Reply With Quote
Old October 5th, 2007, 07:43 AM   #3
Hi Petr,
Thanks for your advice. I gave it a good pull and finally was able to detatch it,
Cheers
Paul J
