Cannot seem to log and capture
Recently updated firmware on GYHD100 and now cannot seem to
get my log and capture to work. Updated with proper download Working in FCP Studio2. Did just reinstall FCP after system problem. Anyone have any idea? Thanks Ken Vaughan |
Hi Ken.
My first line of thinking is to determine whether it's a problem with your installation of FCP or if you've got a camera problem (whether a faulty firmware update or even a blown FireWire port or the HDV/DV switch in the wrong position, etc.). When you say "updated with proper download", I'm not totally sure if you're referring to an update of FCP or the camera firmware. Camera-wise, have a look at the "sticky" for this forum called "ALERT: Power OFF before connecting/unconnecting Firewire or switching HDV/DV" and see if it's not a problem with that. One way to quickly isolate whether it's the camera or FCP would be to borrow a cheap little mini-DV camera from a friend or relative and see whether FCP will capture the DV footage from that. If it doesn't, you have an FCP problem. (Alternately, you could take your camera over to someone else who has a working version of FCP 5.1.2 or above on their computer and see if it will capture on that.) Those are my initial ideas. |
You could also use DVHScap to see whether the cammera communicates properly via firewire. I´ve had lots and lots of problems with Finalcut in that regard.
