Jvc Cu-vh1 at DVinfo.net
Old August 13th, 2007, 10:34 AM   #1
Jvc Cu-vh1
What's the trick to capturing via firewire to your PC, i don't know what i'm doing wrong...is there software that was supposed to come with the unit???
Martin Patterson is offline   Reply With Quote
Old August 13th, 2007, 11:47 AM   #2
Martin,
There isn't any digitizing software that comes with the deck. You can capture m2t using a program called CapDVHS. It's free and you can google for a link. What are you using for your editing program?
David Parks: DP/Editor: Jacobs Aerospace at NASA Johnson Space Center
https://www.youtube.com/user/JacobsESCG
David Parks is offline   Reply With Quote
Old August 13th, 2007, 11:54 AM   #3
jvc cu vh1
we use liquid, premier pro, pinnacle studio 11
Old August 13th, 2007, 12:30 PM   #4
You should be able to capture directly into Avid Liquid all frame rates from JVC ProHD line of cameras. However, the Cu-vh1 has been listed by several NLE manufacturers as not completely compatible for digitizing/digitalcut. Unfortunately this is an older deck that JVC no longer manufactures. You may have better luck capturing from a JVC HDV camera.
Other digitizing sofware: HDVsplit, and if you're using Ppro and Liquid, you might invest in Cineform NEO at $249. Try CapDVHS and then import m2t into your editing program.
Good Luck
Old August 13th, 2007, 12:36 PM   #5
jvc
we have a JVC HD100, JVC HD7, JVC DV500 and a PANASONIC HVX200 Just made the switch...we sold our DVX 100's on Ebay
