Camera error - Blue dot on footage at DVinfo.net
Go Back   DV Info Net > And Now, For Something Completely Different... > The Archives > JVC GR-HD1U / JY-HD10U
All about the original single-CCD HDV camcorders from JVC.
Old June 3rd, 2006, 02:38 AM   #1
Hi,
I have a JVC GR HD1 camcorder. Now when I capture video all footage has a light blue dot at the bottom right hand side of the footage. This seems to have started maybe a few months ago.
I have tried the following:
1. Different tapes >> same problem
2. Used cleaning tape >> same problem
3. cleaned front of lens >> same problem
4. recorded with LCD and without >> same problem
When recording footage using the LCD I can see a faint bluelike pixel in the bottom right of the screen.
Could anyone offer suggestions as to what to do to resolve this error?? Has anyone experienced this type of problem before??
Camera owes me a small fortune and is out of warranty so I'm shaking in my boots.
Many thanks in advance for any feedback.
Troy Haines is offline
Old June 3rd, 2006, 02:31 PM   #2
I would contact JVC tech support, and see what they have to say. They should be able to give you a local repair depot.
Damnit Jim, I'm a film maker not a sysytems tech.
Ken Hodson is offline
Old June 4th, 2006, 04:14 AM   #3
Sounds like a "stuck" pixel on the CCD. :-(
Martin at HeadSpin HD on Blu-ray
Martin Mayer is offline
Old June 20th, 2006, 05:54 PM   #4
pixel
I have a similar problem. At first I thought it was just on the LCD screen, but when I saw it played back on the computer, I saw the dot on the screen also. It's a white dot. Dead pixel I'm pretty sure...
Bummer.
Carlos Rodriguez is offline
Old August 10th, 2006, 06:39 AM   #5
New CCD block should be about 180 USD (150 EUR) + service.
I had mine fixed. When it gets back, be sure to screw in a wide lens adapter and check for asymmetric vignetting - sometimes they "forget" to line up the optical stabilizer. It happened to me, but it's an easy - almost instant - fix.
Best
Hugo
Hugo Pinto is offline
Old August 27th, 2006, 04:50 AM   #6
Thanks for all the replies. I sent the camera off to a jvc repair centre of replaced the ccd for free out of goodwill. Apprently the ccd is a sony and was known to have some faults.
Cheers
Old August 30th, 2006, 10:07 PM   #7
same problem...
I used to get blue, green, and if remember correctly even red dots after the camera was on for a real long time. I did have the ccd replaced and have not tested under long running times yet. I did get a full concert dvd done with it that will be in stores november 21st.
www.capturemotiondvd.com
John Lorince
Http://capturemotion.tv
John Lorince is offline
  You are here: DV Info Net > And Now, For Something Completely Different... > The Archives > JVC GR-HD1U / JY-HD10U
