On-camera Light for JY-HD10U at DVinfo.net
Go Back   DV Info Net > And Now, For Something Completely Different... > The Archives > JVC GR-HD1U / JY-HD10U
All about the original single-CCD HDV camcorders from JVC.
Old July 8th, 2005, 01:55 PM   #1
Does anyone have suggestions for an on-camera light for the JY-HD10U? Unfortunately, the low-light performance of this camera leaves much to be desired. :(
I don't know much (well, anything) about on-camera lights. Is there a lot of variation in the color cast of camera lights? Also, are there any that use LEDs, like the hiking headlamps I've seen? I've seen LED underwater camera lights, but not regular camera lights.
I'd appreciate any suggestions.
Thanks.
- Caitlin
Caitlin Weigel is offline
Old July 8th, 2005, 10:02 PM   #2
Saw this
Hi,
I am new but I am also looking for the same thing and saw your post. Indeed, things are great when you give this cam enough light.
Saw this site about the LED lights but it gives a spooky look, as LED lights do. Im not doing a recommendation as I have never used it.
http://www.camerabright.com/
Allen Lu is offline
Old July 9th, 2005, 06:16 PM   #3
Litepanels are good for LED lighting, as they're balanced properly, but they are quite epxensive ($1000ish, been a while since I've checked). I hope somebody realizes the need for good, properly balanced LED camera lights at a low price point.
Tom Wills is offline
Old July 14th, 2005, 10:44 PM   #4
Tried the X1-ER
This model is the brightest of the three but because of the GR-HD1's pod mount position, the light would case a shadow from the lens hood.
It would be better to get a light that fits on the shoe with the handle.
Allen Lu is offline
  You are here: DV Info Net > And Now, For Something Completely Different... > The Archives > JVC GR-HD1U / JY-HD10U
