1/30 or 1/60 shutter speed? at DVinfo.net
Go Back   DV Info Net > And Now, For Something Completely Different... > The Archives > JVC GR-HD1U / JY-HD10U
All about the original single-CCD HDV camcorders from JVC.
Old January 19th, 2005, 01:04 AM   #1
I'm test driving the HD10U and was wondering what shutter speed is "ideal" when shooting 720p? Since it's progressive, is 1/30 the ideal? The thing that confuses me is that on Pana's AG-DVX100, the ideal shutter speed is 1/48. In the film world, I'm led to believe the shutter is set to 180', which is twice the frame rate (24 fps with 180' shutter is equivlant exposure to 48 fps, or something like that). So does this mean that 30p looks better with a shutter speed of 1/60?
Xander Christ is offline
Old January 20th, 2005, 06:04 PM   #2
MPS Digital Studios
With the DVX100A, we stick with 1/60, believe it or not. But that's for our DVX100A page...
I recommend 1/60 for the HD10.
hwm
My Final Cut Pro X blog
Heath McKnight is offline
Old February 25th, 2006, 06:52 PM   #3
MPS Digital Studios
Update: After tons of tests with the DVX100a, I like the shutter of 1/50. You could use syncro-scan to go to 1/48, but there's a weird jittery look. Stick with 1/50.
heath
Old February 25th, 2006, 09:14 PM   #4
I sure won't do 1/30 hand held.
Robert M Wright is offline
Old February 26th, 2006, 04:13 PM   #5
I find the look of 1/60th preferable to 1/30th which give a strong motion blur to fast movement. That said the cam likes to revert to 1/30th in HD mode unless you have way to much light, which will let the shutter climb. If you are shooting locked down tri-pod with medium to long shots 1/30th works fine. If your shooting close with little movement then it is also OK. Because the cam likes to revert to 1/30 in HD (as opposed to 1/60 in SD) you have the option to lock the exposure, where as if you want 1/60th you will most likely have to lock the shutter to that speed, making an exposure lock unavailable. Of course there are ways to get around that, but it isn't as simple as pressing a button.
Damnit Jim, I'm a film maker not a sysytems tech.
Ken Hodson is offline
Old February 26th, 2006, 07:21 PM   #6
The HD10U does challenge you, but you can get some great images (and it will force you to learn more about the fundamentals of image acquisition).
Old March 2nd, 2006, 02:32 AM   #7
HDV Cinema
Ken's got it.
After working out ways to get 1/60th because that is technically correct -- in India this last year I decided to use the HD1 like I had been using an HD100.
Use ND to get 1/30th second (because you can set shutter-speed) and then adjust exposure as needed.
On slowly moving subjects, the blur almost makes no difference.
On rapidly moving subjects, the blur "covers" the strobing.
So I rewote the HD1/HD10 Shooting Guide that's in my HD100 Handbook.
Steve Mullen is offline
Old May 12th, 2006, 08:00 PM   #8
Hd10 shooting guide
Is it possible to get just the appendix about hd10u shooting from your guide?
Xavier Agudo is offline
Old May 13th, 2006, 10:53 AM   #9
HDV Cinema
I'm considering this. I want to add a bit on using the Focus HDD with these camcorders. Look for an announcement at the end of May here.
I'm also rewatching stuff I shot with an eye to focus issues. I noticed I got into a bad habit of going for extream CUs. When doing so, the critical focus range is only a few inches! Seems my eyes can't see on the LCD the tiny bit the camera may be out of focus. But on my new 50-inch -- too many shots are just slightly out of focus.
By the way, there is a thread on shooting 30p:
http://www.dvinfo.net/conf/showthread.php?t=66947
  You are here: DV Info Net > And Now, For Something Completely Different... > The Archives > JVC GR-HD1U / JY-HD10U
