For football coverage... at DVinfo.net
Go Back   DV Info Net > And Now, For Something Completely Different... > The Archives > JVC GR-HD1U / JY-HD10U
All about the original single-CCD HDV camcorders from JVC.
Old July 20th, 2004, 06:32 AM   #1
I have to choose between the HD1 and 10 as the best camera to use for taping football games for post-game analysis. I have a couple questions...
1--Has the audio distortion problem been solved once and for all?
2--Was that problem heard in both cameras?
3--Given that I'll be distributing the games on VHS to the coaches, is it your opinion that the HD1's edge enhancement would be a plus in this case?
4--To convert to VHS from HDV, do I need a playback deck to do that or is the cable out of the camcorder sufficient?
Thanks in advance. I'll hang up and listen off the air!
Lynne Whelden is offline
Old July 21st, 2004, 08:25 AM   #2
MPS Digital Studios
Re: For football coverage...
<<<-- Originally posted by Lynne Whelden : I have to choose between the HD1 and 10 as the best camera to use for taping football games for post-game analysis. I have a couple questions...
1--Has the audio distortion problem been solved once and for all?>>
Yes. But it was the HD10 with a mic plugged into the XLR.
<<2--Was that problem heard in both cameras?>>
No. But the HD1 has more edge enchancement than the HD10 (my recommendation).
<<3--Given that I'll be distributing the games on VHS to the coaches, is it your opinion that the HD1's edge enhancement would be a plus in this case?>>
See above. But I would definitely NOT use the HD1. Okay, that's a bit harsh, sorry. But for just a little more money, you can get the HD10. Check out this training DVD from Darren Kelly for more.
<<4--To convert to VHS from HDV, do I need a playback deck to do that or is the cable out of the camcorder sufficient?>>
I had no problems using the VHS deck hooked up to the camera and hitting play on my NLE's timeline and using the camera as the "middle man." What kind of edit system are you using?
<<Thanks in advance. I'll hang up and listen off the air! -->>>
No sweat!
heath
My Final Cut Pro X blog
Heath McKnight is offline
Old July 21st, 2004, 03:18 PM   #3
For this project I'm not using any edit system nor do I have one for HDV yet. Been looking at the Solitaire system that MacroSystems is developing, however.
Old July 21st, 2004, 07:35 PM   #4
Just out of curiosity, why HDV for this aplication. A 4:3 cam with easy to manage manual control would probably do you better, at less money. Don't ya think?
Damnit Jim, I'm a film maker not a sysytems tech.
Ken Hodson is offline
Old July 21st, 2004, 07:55 PM   #5
I've got a 4:3 camera and I've worked in DV for too many years. I'm hoping the increased resolution will be a plus for watching the subtle aspects of play action. Also I'm thinking widescreen is a more pleasing and natural way to view a football game. Basically I'm looking for a legitimate excuse to buy this camera and break into the world of HD!
Old July 22nd, 2004, 09:04 AM   #6
<<<-- Originally posted by Lynne Whelden :Also I'm thinking widescreen is a more pleasing and natural way to view a football game. Basically I'm looking for a legitimate excuse to buy this camera and break into the world of HD! -->>>
Then maybe you should consider a 16:9 HD monitor for playback.... While it's arguable that a higher rez. source will always produce a superior down-rezed product, 'chopping' the 16:9 HD clips from the HD10 (the preferred option over the HD1 IMO) to 4:3 VHS level won't yield results that are 'streets ahead' of what you're getting already.
With prices on good 76cm-86cm HDTV CRT 16:9 monitors/tv's at damn good prices you would get excellent results by connecting the cam with the supplied component cable for direct playback at 1080i on such a unit.
Steve Crisdale is offline
Old July 22nd, 2004, 09:39 AM   #7
Twin-cam setup for Sports recording
Check out this tripod mount for use in capturing both the wide-field view and following the ball in a narrower view...simultaneously with two cams by one cam operator.
http://www.coachcomm.com/product_accessories_video.html
Look about halfway down the page on the left for the Dual Camera Support Plate.
This is the excuse you needed to buy that second cam!!!
Fear No Weevil!
Patrick King is offline
Old July 22nd, 2004, 10:10 AM   #8
Wait a minute. I'm starting to get confused. I can get a letter-boxed 16:9 output from this camera (or a deck), can't I? Just because I"m putting it onto VHS doesn't mean I loose the widescreen, does it?
Old July 22nd, 2004, 01:43 PM   #9
MPS Digital Studios
Lynne,
All your questions about the camera's features answered right here.
It IS a native 16x9 camera, in both SD and HD modes.
For more information, check out our own site, HDV Info Net.
As for editing, why are you waiting for a system that isn't out yet, when you can be cutting on both Apple with Final Cut Pro and Lumiere HD; and PC (like Dell, etc., using Windows XP Pro) and CineForm's Aspect HD bundled with Premiere Pro?
heath
Old July 22nd, 2004, 02:48 PM   #10
I shoot the game films for my kid's high school and started using a two camera setup halfway through last season. I want a wide and a close up view - wide for the coaching staff and close up for my end of year highlights DVD.
The dual camera support plate at "coachcomm" doesn't show you anything about how it is constructed or what it costs. Bogen makes an adapter (3269 Double Camera Support Platform) that allows you to mount two cameras to one tripod, goes for just over $50. It's very nice.
I made my own with a piece of 1/8" x 1" x 12" bar stock, some washers, nuts and bolts, all for less than $6.
One other thing. I don't understand how the increased resolution of HDV can be any benefit when you dub to VHS for the coaches. You are limited by VHS's capability, which is far below what an HDV cam can deliver.
Mike Hanlon is offline
Old July 22nd, 2004, 04:28 PM   #11
garbage in....
I'm assuming this to be true...
35mm film dumped to VHS looks better than 8mm film dumped to VHS.
The sharper the original signal, the sharper the end product.
Thus an HD camera whose signal is dumped to VHS is surely going to look better than a VHS camera or a DV camera's signal put on VHS.
Or am I missing something???
Old July 22nd, 2004, 04:47 PM   #12
Lynne,
If the original footage was captured with three cams simultaneously, one S-VHS, one DV standard definition, and one DV high definition, and all three were setup as closely as possible, you wouldn't see a difference because the long pole in the tent is the very poor VHS resolution.
Fear No Weevil!
Old July 22nd, 2004, 04:53 PM   #13
Has someone actually done such a test?
Old July 22nd, 2004, 05:29 PM   #14
A direct test isn't necessary (though I'm sure some have been done somewhere) since the physical limitations of each recording technology are known.
VHS is limted to 240 lines of resolution.
DV is about 500.
HDV is what, 720 (or is it 1080?).
VHS can't ever do better than 240 lines, no matter how good the source material you start with, so every bit of resolution above 240 lines will not be recorded on the VHS tape.
Old July 24th, 2004, 07:03 PM   #15
Well Mike your right to a certain point. But I am sure you would agree that a movie that originated on 35mm looks miles ahead of DV when both are down sampled to VHS. DV aliasing is still very evident, as well as lack of fine detail. You don't see aliasing when watching TV shows, but you do when you watch your DV on your TV.
  You are here: DV Info Net > And Now, For Something Completely Different... > The Archives > JVC GR-HD1U / JY-HD10U
