HDV Stream Type at DVinfo.net
Go Back   DV Info Net > And Now, For Something Completely Different... > The Archives > JVC GR-HD1U / JY-HD10U
All about the original single-CCD HDV camcorders from JVC.
Old July 7th, 2004, 03:11 PM   #1
HDV Stream Type
Hallo!
I was wondering if somebody could maybe help me with a question: There are two HDV standards one uses the MPEG PES and the other the TS stream type.
My question now is, if a MPEG PES stream does not have to be multiplexed in either a programm or transport stream, since this is what I read in all books?
Or are the single PES streams worked on seperatly?
I would be very thankful for an answer!
Bye
P.S.: iLink TS - is this a special variation for iLink ?
Anja Schuetz is offline
Old July 7th, 2004, 07:16 PM   #2
MPS Digital Studios
iLink is a firewire connection.
heath
My Final Cut Pro X blog
Heath McKnight is offline
Old July 8th, 2004, 01:44 AM   #3
Well, I know that iLink and Fire Wire are the same thing. I am simply confused because TS ist always pointed out in connection with the HDV specs.
Thank you though!
Old July 8th, 2004, 09:43 AM   #4
Firewire (1394) is only data transmission - there are 1394 hard drives - has nothing to do with video or audio.
A program Stream (PS) - as it relates to MPG - reshuffles the data to allow for SOME error identification and correction.
A transport stream (TS) adds a bit of data for error correction, making the data more robust, presumably for the arduous journey through a diverse data jungle.
I don't really know much of the specifics, but I do remember a tidbit of information concerning data on CDs. Before going on the CD, the data stream is subjected to a process called 8 to 14 modulation. The final stream can not have fewer than 3 nor more than 11 ones OR zeros in a row. This keeps the stream active. If a decorder finds a stream of ones or zeros outside this fairly tight parameter, it knows an error has occurred. As a result error correction and error masking techniques, the CD could play flawlessly through a 1/8" hole in the disk. I seem to recall that was one of the design parameters.
After using VLC to convert a TS to a PS, the files are always a little smaller.
Dave
David Kennett is offline
Old July 8th, 2004, 09:55 AM   #5
Old July 9th, 2004, 12:02 PM   #6
Well I got news and found out, that there actually is a PES stream- not multiplexed- on tape when recording in 1080i. The steam will be transferred into a TS before sending over Fire Wire!
How this is done and exactly where in the signal processing is a secret of the HDV developers-so...
No more information to be found! Bye!
  You are here: DV Info Net > And Now, For Something Completely Different... > The Archives > JVC GR-HD1U / JY-HD10U
