Spider footage: (In honor of Wed. 30th) at DVinfo.net
Go Back   DV Info Net > And Now, For Something Completely Different... > The Archives > JVC GR-HD1U / JY-HD10U
All about the original single-CCD HDV camcorders from JVC.
Old June 26th, 2004, 04:56 PM   #1
UPDATE: I had to pull the footage. 5gb of bandwidth doesn't last as long as I'd hoped.
I messed around some more with the HD1 last night: found a visually nice spider web with it's inhabitant.
I've posted it, but if the bandwidth gets munched up, it'll come down. Also, could anyone using Speed-Download or other download utility that opens an assload of streams, please not use it here? They bring my lowly server to a stand-still.
http://www.marklove.com/spider.ts (56 mb)
Shot mostly with SS 1/30, w/ Tiffen Low Contrast Filter. Not much done in post.
Thanks-
Mark
Equipment: GY-HD100, DP 1.8 GHz G5, FCP 5
Mark Love is offline
Old June 26th, 2004, 05:50 PM   #2
Nice!!!
Interesting.... Where I notice the HD1 has the most problem with EE is in high contrast situations. The filter may help that issue.
Mike
http://www.acdnow.com
Mike Eby is offline
Old June 27th, 2004, 12:02 AM   #3
How about making an 8 megabit Media 9 out of it, to reduce your download burden ? Just an idea.
Les Dit is offline
Old June 27th, 2004, 03:51 AM   #4
Maybe it's just my player...but at the very top of my image I see a thin white or clear line. Was this in the original?
Glenn Gipson is offline
Old June 28th, 2004, 11:25 AM   #5
Nice footage! The really close shots near the end of the footage looks fabu!
Yeah, I was using WinDVD for playback and had the thin white line in the upper part of the footage as well.
Troy
Troy Lamont is offline
Old June 28th, 2004, 01:27 PM   #6
OIS on or off?
Hey Mark,
Nice spidey shots..you're making Peter Parker very nervous. When you were zoomed in very close, I thought I detected a little bit of blurring on the spider as the wind moved the web. Was the optical image stabilization (OIS) on or off when you took these shots? My guess is that it might have been on.
scott
Scott Frase is offline
Old June 28th, 2004, 01:54 PM   #7
RE: OIS
Hey Mark,
...Was the optical image stabilization (OIS) on or off when you took these shots? My guess is that it might have been on.
Right you are. I am not 100% familiar with the camera's controls yet. Is the OIS a bad thing?
Old June 28th, 2004, 02:41 PM   #8
Hey Mark,
In general, OIS isn't a bad thing if you're doing handheld work. In my own shots, however, I noticed a bit of image blurring if my camera was on a tripod. I just couldn't figure out what was causing it. (I suppose this is why I mentioned OIS in the first place).
I'm guessing that you used a tripod for those spider shots as the camera didn't seem to move much. If your camera is stable (on a tripod or otherwise not moving), the manual suggests turning off OIS. The funny thing is though, the manual doesn't give us a reason as to WHY you should turn OIS off if you're using a tripod. So I did a search on this board and Darren Kelly had to say this on the following thread (http://www.dvinfo.net/conf/showthread.php?s=&threadid=22395&highlight=ois):
"On a tripod with it on, you could see the OIS provided some blurr because OIS systems don't know what to do when the camera is stable."
This is not much of a technical explanation as to the cause of the problem, but an observation based on experience with the camera.
Generally, I tend use OIS when I'm using the HD10 handheld only.
scott
  You are here: DV Info Net > And Now, For Something Completely Different... > The Archives > JVC GR-HD1U / JY-HD10U
