#91 |
Roger, shoot me an email and I'll host your clips here at DV Info Net.
#92 |
Chris,
I am out of state until Aug. 10th. I will email you a clip as soon as I return along with photos of my set up. Roger |
#93 |
720P GG video sample
incidentally, I started a thread with my first results off my HD10 35mm device. Sample video in both media9 and mpeg2 at reasonable bit rates.
http://www.dvinfo.net/conf/showthrea...threadid=30235 -Les |
#94 |
roger,
have you even reached home? let's put this footage online for us to see thanks a lot :) ciao |
#95 |
I should get my free bandwidth back, but I'd be happy to upload my clip as well.
Thanks! -Les |
#96 |
In case anyone is curious in seeing the results of the Agus35 with the GR-HD1, here's a link to a sample quicktime movie and a couple of stills.
http://s92673533.onlinehome.us/media/35/35.htm Direct link to the movie http://s92673533.onlinehome.us/media/35/focustest.mov It has been reduced and resized, since the WMV files are nowhere near indicative of the actual results. Once I figure out a better compression setting for the .wmv format I'll try uploading it.
Gene |
#97 |
If you use the right settings on the WMV media9 file, they are *very* indicative of the results. Try using 8 megbits/sec, and full 720P ( 1280 x 720 ) size. Use 2 pass encoding too, if at all possible. Only a few seconds are needed. Having the camera held still for a couple of seconds shows some artifacts that don't show on shaky cam type shots too , BTW.
Looks great so far! -Les <<<-- Originally posted by Gene Celso : In case anyone is curious in seeing the results of the Agus35 with the GR-HD1, here's a link to a sample quicktime movie and a couple of stills. http://s92673533.onlinehome.us/media/35/35.htm Direct link to the movie http://s92673533.onlinehome.us/media/35/focustest.mov It has been reduced and resized, since the WMV files are nowhere near indicative of the actual results. Once I figure out a better compression setting for the .wmv format I'll try uploading it. -->>> |
#98 |
http://s92673533.onlinehome.us/media/35/pullfocus_large.wmv
This shot is from the same footage as the last one, only this time the camera is static and is pulling in and out of focus. I encoded this as a .WMV file at 720p with around 8megabits/sec. (There is however some banding occuring around the gradients)
Gene |
#99 |
You are missing a zero on the bit rate.
You encoded 800 K bits / sec, not 8000 K bits. That's the reason for banding, FYI. -Les <<<-- Originally posted by Gene Celso : http://s92673533.onlinehome.us/media/35/pullfocus_large.wmv This shot is from the same footage as the last one, only this time the camera is static and is pulling in and out of focus. I encoded this as a .WMV file at 720p with around 8megabits/sec. (There is however some banding occuring around the gradients) -->>> |
