Blue/Greenscreening with HDV at DVinfo.net
Go Back   DV Info Net > And Now, For Something Completely Different... > The Archives > JVC GR-HD1U / JY-HD10U
All about the original single-CCD HDV camcorders from JVC.
Old January 30th, 2004, 09:42 PM   #1
Hi. I had a question for all you technical guys out there. Do you know if it is easier to key HDV or DV. I wonder if DV compression, or MPEG2 compression of HDV is better suited for chroma keying.
I do alot of blue/greenscreen shots for visual effects, and I was wondering how easy it would be to key HDV with something like primatte. Has anyone tried this?
Daniel Broadway is offline
Old January 30th, 2004, 10:42 PM   #2
Frederic Haubrich and Darren Kelly have both posted examples of chroma key using JVC HD in this forum.
In theory the camera's 4:2:0 sampling method should be an advantage over DVs 4:1:1 for keying, not because there is more color information (there isn't) but because the chroma information is less spread out than in 4:1:1
If your final output will be DV, downsampling will be an advantage if you use HDV.
I also did some keying and found the chroma noise that the camera produced to be the biggest problem, I think the compression is less problematic. People here are working on methods for cleaning up chroma noise which should help keying with this camera greatly.
I havn't tried primatte, but I would be concerned that it was built for DV and would probably be more effective with 4:1:1 footage.
Paul St. Denis is offline
Old January 31st, 2004, 11:49 AM   #3
MPS Digital Studios
Daniel, do a search:
http://www.dvinfo.net/conf/search.php
under HDV and greenscreen, or even Darren Kelly or Frederic Haubrich and you'll find some info.
heath
My Final Cut Pro X blog
Heath McKnight is offline
Old January 31st, 2004, 02:49 PM   #4
Humm, that is interesting. I wonder if 3CCD HDV camera would have better keying results. In my experience keying DV, it's not so much the compression that hurts the keying.
Edge sharpening and 1CCD cameras are the most problematic cameras to try to key from.
Primatte keys DV footage beautifuly. However, it is not designed for DV. It is designed for high end 35mm film keying and compositing.
Old January 31st, 2004, 03:33 PM   #5
Both Primatte & Ultimatte work quite well with HD10, which one to choose depends on footage. As EE is quite low on HD10, it makes things easier as well. HDV seems way better for keying to me.
Also, I got best results by removing chroma noise first and then keying.
Helen Mets is offline
Old January 31st, 2004, 07:42 PM   #6
Helen, could you perhaps post screen shots of your keying with Primatte?
Old April 29th, 2004, 08:28 AM   #7
Bluescreen CHROMA KEY for HDV
Did any bluescreen chroma key shoots with the HD10U or HD1? Anything special to pay attention to in both shooting and editing? Please share your experience here. Thanks!
Ray Van Eng is offline
Old April 29th, 2004, 08:47 AM   #8
I don't have any info yet but I have a day long greenscreen shoot with the hd10 on sunday and will report my findings.
Mark Jervis is offline
Old April 29th, 2004, 08:52 AM   #9
Marvelous, Mark! Have a great shoot.
Old May 1st, 2004, 10:16 AM   #10
Experimental chroma key shoot
I have been doing very simple 'green screen' shootings, and found out that the camera performs nicely if you take standard rules into consideration:
2. Light your bluescreen evenly (no shadows or hotspots)
3. Place your actors with enough space in front of your screen so that light reflecting from it wont cause green spill.
4. Light your actors/set/props accordingly.
5. Use good Chroma key software/hardware
I've been using Vegas 4.0 to add the effect. This software is quite flexible (for its price), and will let you make some adjustments if your bluescreen scene has some lighting errors.
The extra sharpness of the HD1's image made my life easier in post, since had considerably less greenspill than the results I got from a XLS-1 i borrowed before.
Cheers,
Mauricio
o--------------------------o
Life is short.. Live it!
Mauricio
Mauricio DelaOrta is offline
Old May 3rd, 2004, 01:27 PM   #11
MPS Digital Studios
Do a search for Greenscreen HD10; I know someone did it...
heath
Old May 7th, 2004, 01:01 AM   #12
Thanks for the info, Mauricio. Specifically for Vegas 4.0, I was actually leaning more towards getting the Premier but I have read some not so good comments concerning the Adobe software’s handling of chroma key subjects.
I would imagine all the usual rules apply in lighting the screen, but was a bit surprised to hear you say that the extra sharpness of HDV actually helped the chroma key shots, i.e. less green spillage. Interesting. I am more of a Bluescreen person myself being growing up in a TV station environment.
Would love to read more comments from other people, not just in shooting but also editing too. Thanks in advance.
Old May 7th, 2004, 07:58 AM   #13
CTO, CineForm Inc.
Green-screening has a slight advantage of using blue for any sampled chroma video system (DV 4:1:1 and HDV 4:2:0), as the green holds more signal in the luma, resulting in a sharper key.
The issues of chroma-keying will be the same whether you use Sony or Adobe products -- it primarily depends on your setup efforts. However, does have an impact and I know higher-end keyers are available for After Effects and Premiere, so there is a lot of choice.
David Newman is offline
  You are here: DV Info Net > And Now, For Something Completely Different... > The Archives > JVC GR-HD1U / JY-HD10U
