Ok, so has anyone ACTUALLY done a 35mm blow up from an HD10? - Page 3 at DVinfo.net
Go Back   DV Info Net > And Now, For Something Completely Different... > The Archives > JVC GR-HD1U / JY-HD10U
All about the original single-CCD HDV camcorders from JVC.
Old January 16th, 2004, 08:47 PM   #31
No, 2K only. Almost all DI work is 2K, for 4 perf 35mm work.
-Les
<<<-- Originally posted by Rob Belics : Can your lab do 4k scans? -->>>
Les Dit is offline
Old January 17th, 2004, 09:51 AM   #32
Yeah, that's sad.
How long does it take, ie, per minute or whatever?
Rob Belics is offline
Old January 17th, 2004, 12:28 PM   #33
It takes about 600 frames an hour.
It's not the 2K res you need to be 'sad' about, because thats not the problem (limit) what it's all said and done.
Most theaters projection quality is what's the issue. Due to frame registration jitter, and poor optics ( the kid doesn't focus) the resolution is about 1000 pixels across, at best.
A good percentage of theaters are really DVD quality, I'd say.
-Les
Les Dit is offline
Old January 17th, 2004, 03:00 PM   #34
Les,
Where do you get for film scan done? $10k seems cheap. How much film is being scanned for $10k?
What are you editing on?
Film out is still pretty expensive right? I see numbers like $300 per minute.
Mahalo,
Dusty
Dustin Cross is offline
Old January 17th, 2004, 06:24 PM   #35
dustin
The scan he's talking about is scanning the dailys to a digital format. Telecine.
the digital intermediate is on your hard disk
you can burn this out for the $300/minute you mention is burning the edited film + sound to 35mm film.
James Ball is offline
Old January 17th, 2004, 06:56 PM   #36
I understand the entire DI process. Actually he is not talking about telecine. Telecine is the process of scanning film and converting it into video. Typically used for offline. He is doing full rez 2K scans.
I am interested in hearing about how many feet of film he is scanning at 2K for $10K. $10K isn't that much. My problem would then be how to get that footage to me in Hawaii. 2K scans can add up to a lot of TB.
Mahalo,
Dusty
Old January 17th, 2004, 07:57 PM   #37
No Telecine here. Full 2K Cineon files, with full chroma res, as opposed to the HD transfers that give you lower quality.
7000 ft ( 80 min) for $10K
As far as getting the files shipped, all I can say is that 200 plus gig firewire drives are getting mighty cheap these days !
I used to use 35 gig DLT tapes, but those are obsolete now.Also, I have a file format that supports compression with 12 bits per channel, that makes each frame about 5 meg instead of the normal 10 megabytes.
I'm not new to this, trust me :)
-Les
Les Dit is offline
Old January 17th, 2004, 08:45 PM   #38
Les,
What file format are you using?
I was recently reading about a new Lacie 1TB firewire drive that would make things easier.
Is it your business that does the scans or do you send it out?
Mahalo,
Dusty
Old January 17th, 2004, 11:59 PM   #39
I own the scanner, but it is run by a small company for me, which I have an agreement with. You can email me privately if you would like to pursue this, since it's getting a bit off topic here on the DV forum. My mail is lesd@earthlink.net.
A small TB drive array would do it, or even a couple of 300 gig drives. FedEx is a good slow speed network. The drives would be passed back and forth a few times, during the project.
I can get some good laser output rates as well, either at the company that runs my scanner, or a large studio I have some connections with. Both are Arri Lasers.
-Les
Les Dit is offline
Old January 18th, 2004, 10:04 AM   #40
RED Code Chef
If my math is correct the cineon files are around 12 MB per frame
(instead of 10, (2048 x 1556 x 30) / 8 = 11.95), which yields
288 MB per second (at 24 fps), or 17280 MB per minute (17 GB).
For those 80 minutes that would be 1382400 MB which is roughly
1350 GB or 1.3 TB. Or five 300 GB drives.
Rob Lohman, visuar@iname.com
Rob Lohman is offline
Old January 18th, 2004, 12:54 PM   #41
Thanks Rob,
I like to use 10 to make my mental math easier!
The 300 GB drive mechanisms are about $270 these days, making them much cheaper than the old DLT tapes that were the industry standard for file swapping only 2 years ago.
-Les
Les Dit is offline
Old January 25th, 2004, 11:10 AM   #42
les dit re: rez
yo les,
i remember you writing on usenet that the most rez anybody will ever squeak out of 16mm color neg is about 1700 pixels across, and any more than that is just sub-sampling the grain.
obviously there's a big difference between 7245 shot at f8 on a sunny day through a $5000 prime, and 7279 shot at f2 with a filmschool bolex. so i assume grainier stocks shot under non optimal conditions can probably be scanned at less that 1700 wide. but how much less? 1k?
heres another question:
when you scan 16mm do you scan at 2k and then scale it down to 1280+ , or do scan a 1700 wide window out of a 2k area.
Chaim Bianco is offline
Old January 25th, 2004, 02:12 PM   #43
Hi Chaim,
As you know, film stocks are evolving along with video, and the newest stocks from Eastman are showing almost no grain. With super 16, we get the full 2K across and resize to a smaller frame as needed. As disk storage is so cheap now, it's feasible to deliver uncompressed frames to the client.
To compete with the HD transfers, the scanning rates have dropped well below 10 cents a frame. In fact, the cost more depends on if the film is being scanned as a cut negative, or in other words, keeping the amount of winding and reel swapping down to a minimum.
-Les
Les Dit is offline
  You are here: DV Info Net > And Now, For Something Completely Different... > The Archives > JVC GR-HD1U / JY-HD10U
