Hot lights and color adjustment at DVinfo.net
Go Back   DV Info Net > And Now, For Something Completely Different... > The Archives > JVC GR-HD1U / JY-HD10U
All about the original single-CCD HDV camcorders from JVC.
Old January 13th, 2004, 01:17 AM   #1
I am using hardware bought quartz lights (1000w, 3200 rating) for lighting purposes. They are pretty good (though not HMI). My question is whether color adjustment (to avoid things like red or blue shifting) for the proper tempreture rating is simply a matter of white balancing the HD10. If not then how do I color adjust when using hot lights?
Dwight Flynn is offline
Old January 13th, 2004, 07:43 AM   #2
Custom white balance should do the trick...
On another note...here is a link for an alternative to using hotlights...
http://www.naturallighting.com/fixtu...worklights.cfm
Carlos
Carlos Salcedo is offline
Old January 13th, 2004, 09:49 AM   #3
Do these lights do just as good a job as an HMI?
I'm looking for alternatives too - this is looks like a great lower price.
Murph
Christopher C. Murphy
Director, Producer, Writer
Christopher C. Murphy is offline
Old January 13th, 2004, 09:56 AM   #4
To be honest...I have no idea...I found the link last night and they are the only company that carries them (they make them exclusively)...but they claim that they have the same output as 1000W tungsten halogens....they also have a color temp of 6000k and a CRI of 85 (not too bad)...
I am very tempted to getting a set and testing them out...I can always return them if they don't pan out...but the idea of having that much light without any heat and long life is way cool...
Carlos
Old January 13th, 2004, 10:30 AM   #5
If you get them could you post a short review? That would really be cool..
Murph
Old January 13th, 2004, 10:32 AM   #6
Sure will...I am waiting on a couple of checks this week and I will get the stand up one and at least one of the smaller ones for fill...
Will post my review and maybe some sample clips or stills...
Carlos
Old January 13th, 2004, 07:02 PM   #7
Lights
Well, the Quartz lights I bought do a great job. I will say it would be nice to get lights you can touch, so I am awaiting the review of these lights. At the same time I will post any similar products I find in my lights research.
Old January 13th, 2004, 07:25 PM   #8
Thanks Carlos!!
Murph
Old January 13th, 2004, 07:36 PM   #9
Now I have a bigger dilema...I found another link with some very interesting lighting options...
http://www.fullspectrumsolutions.com/compact.htm
Check out those 65watt bulbs...4100 lumens, 5500k and 91 CRI...equal to a 300w incandecent bulb...and only $29 each
That could be a very cheap alternative...all you need is some nice reflectors and gobs...
Carlos
  You are here: DV Info Net > And Now, For Something Completely Different... > The Archives > JVC GR-HD1U / JY-HD10U
