ND Filters: One more quick question at DVinfo.net
Go Back   DV Info Net > And Now, For Something Completely Different... > The Archives > JVC GR-HD1U / JY-HD10U
All about the original single-CCD HDV camcorders from JVC.
Old January 12th, 2004, 02:58 PM   #1
MPS Digital Studios
I am about to buy a .3 and a .6 ND Filter from B&H.
On both, they are "grey;" is this something I want? I'll provide links and let me know if that's okay.
Here's the .3.
Here's the .6.
Just so you know, I didn't see anything that said ND .3 or .6, this is what B&H told me to look up.
I also found this and this. Would they be better, though it says 85 mm?
heath
My Final Cut Pro X blog
Heath McKnight is offline
Old January 13th, 2004, 08:02 AM   #2
RED Code Chef
I'm not sure what gray is about. Perhaps send B&H an e-mail
or a phonecall?
Rob Lohman, visuar@iname.com
Rob Lohman is offline
Old January 13th, 2004, 09:18 AM   #3
MPS Digital Studios
Good point.
hwm
Old January 13th, 2004, 11:27 AM   #4
CTO, CineForm Inc.
I'm guessing that "gray" simply points out that this is Neutral Density (ND), is equally reducing light across the visible spectrum, therefore "gray". All the ND filters simply look gray (how else could they look.)
David Newman is offline
Old January 13th, 2004, 05:05 PM   #5
Warden
If you do a search here you'll find out that some ND filters are not so neutral in color rendition. Most notable Tiffen ND filters have a very pronounced warm tone to their image. So, once again not all filters are created equal. I use a Nikon ND filter for several lenses, and a B+W ND for the rest. On occasion I also use Cokin, Lee or Singh Ray filters (square size).
Jeff Donald
Carpe Diem
Jeff Donald is offline
Old January 19th, 2004, 03:33 PM   #6
MPS Digital Studios
Jeff,
What kind of Cokins?
heath
Old January 27th, 2004, 04:22 PM   #7
A few weeks ago I tried out that neat trick of combining two polarizing filters someone had suggested on here. It works great! You end up with an infinitley variable ND filter that goes from about x2 to almost totally black.
I took one lens out of it's holder and stuck it inside the ring of an 812 warming filter. (Two lenses inside a single ring), and then put the other circular polarizer on in front of it. The 812 helps offset the cold, kinda greyish look the filters have, and because I'm now only using two rings, I don't get any vignetting.
The only very wierd thing that took me awhile to get, is that not only did I have to flip ONE of the lenses to get it to work - I had to flip BOTH to find just the right combination. One way wouldn't get much darker, but would change the light from red to blue. If I flipped just one lens, it wouldn't really do anything. When I got both right, it worked great. Bizzarre.......(poor human brained me).
Now, if only the sun would come out so I can try it.
Kevin A. Sturges is offline
Old January 27th, 2004, 05:06 PM   #8
Warden
Heath, I'm not sure I understand your question.
Jeff Donald
Carpe Diem
Old January 27th, 2004, 06:46 PM   #9
He was asking what kind of Cokin filters to you use.
Troy
Troy Lamont is offline
Old January 27th, 2004, 07:48 PM   #10
MPS Digital Studios
Thanks, Troy! That's my question!
heath
Old January 27th, 2004, 09:18 PM   #11
Warden
I use Cokin graduated ND filters and an assortment of colored grads.
Jeff Donald
Carpe Diem
Old January 27th, 2004, 09:25 PM   #12
MPS Digital Studios
Thanks.
heath
  You are here: DV Info Net > And Now, For Something Completely Different... > The Archives > JVC GR-HD1U / JY-HD10U
