JY-HD10U vs. Canon XL1s at DVinfo.net
Go Back   DV Info Net > And Now, For Something Completely Different... > The Archives > JVC GR-HD1U / JY-HD10U
All about the original single-CCD HDV camcorders from JVC.
Old January 5th, 2004, 06:10 PM   #1
Between JY-HD10U and XL1s, which one is better, interm of picture quality?.
Som Xai is offline
Old January 5th, 2004, 06:50 PM   #2
What you are asking is not easy. Comparing an HD cam to a DV cam in term of picture quality is like comparing oranges to apples. Perhaps people with a better knowledge of both cams can point you to some differences on the feature set of theses two camcorders.
Jean-Philippe Archibald
http://www.jparchibald.com - http://www.vimeo.com/jparchib
Jean-Philippe Archibald is offline
Old January 5th, 2004, 08:20 PM   #3
Barry Wan Kenobi
The XL1s will give you a better standard-definition image.
The HD10u will give you a better high-def image.
So, what are you shooting -- HDTV or NTSC/PAL? That'll help you make up your mind as to which camera will produce the better image for your needs.
Barry Green is offline
Old January 6th, 2004, 09:06 AM   #4
If you shoot in HD - then downconver it to SD - you will have a better image than something aquired in SD.
It's simple - the computers compute all the bits to make up a new version of your video - minus whatever it feels is redundant information. (ok, the computer is making the choice. we might disagree, but we're not choosing ever bit...the computer is and that's why choosing a good codec is important.) The more bits you have - the more the computer has to compute/calculate the final version. The final result will be a better video if the computer has LOTS of information to re-calculate.
Does that make sense? I'd Google the word "codec" and read up a little...it's something we should all know about. In short, it means (Co) "Compress" - (Dec) "Decompress". Whenever you take a piece of video into your computer and change it to a new version by taking away "bits" you are using a codec. The whole video community is always in search of the best codec because it means your original video will remain closely intact when you change it....so, HD brought down to SD will always be better than SD not even touched.
On small note: None of this takes into account the optics of the cameras etc. That's another story all together...if a camera has incredible optics and other inside guts...it sure can make a difference. However, it's safe to say that HD cameras have decent optics and guts...otherwise, what's the point?
Murph
Christopher C. Murphy
Director, Producer, Writer
Christopher C. Murphy is offline
Old January 6th, 2004, 10:27 AM   #5
Thanks for all :)
So, if I buy the HD10U, can I still put on DVD and play with the standard TV?. Or does it have to be play on HDTV only?.
I really like the JY-HD10U, but because it's so new and I want to research all the pitfall/ trouble before making decision buying it. What I don't like is that this camera is not Len (interchangeable)...
Again, thank you for helping me.
somxai
Som Xai is offline
Old January 6th, 2004, 10:42 AM   #6
The answer is YES. You can because its not different than any other video file needing encoding for DVD playback.
It's not difficult...don't worry and get the HD10u! :)
Murph
Old January 6th, 2004, 11:44 AM   #7
Anyone know where I can buy the JY-HD10U for a better price?.
I saw one at this website http://www.expresscameras.com/cart/p...d=8698&start=1
It's only $2,189.00. I just not sure if this website is true that it's the JY-HD10U even it said so. Because the HD1 is already $3500.00 at sound track. I just don't think the professional one would cost only less than the comsumer version of the camera.
If you know where has a better price and sure that when I get it, it would be the JY-HD10U, I would very much appreciated.
Thanks in advance.
Som Xai is offline
Old January 6th, 2004, 12:42 PM   #8
MPS Digital Studios
That seems to be TOO low in price, and the number one rule is, if it's too good to be true, it probably is! I don't want you to get in trouble!
I went with a Camera Dealer, which was FANTASTIC, but you may want to go with B&H to save some money vs. a dealer.
heath
My Final Cut Pro X blog
Heath McKnight is offline
Old January 6th, 2004, 01:33 PM   #9
I bought the HD10 for HiDef, but I realize now that there will be many times when SD will still be needed. The problem is getting a quality conversion, and crop the image to 3:4. (I have never been a fan of letterbox.) You can make analog copies from the camera as letterbox or anamorphic - but not cropped. I have a post on the editing forum on using TMPGEnc to make cropped DVD. I am very pleased with the quality - and I have the HD master as well.
If anyone has a place to post it, I could make a short DVD compliant MP2 file with some samples.
Dave
David Kennett is offline
Old January 6th, 2004, 02:16 PM   #10
So! Dave, should I go with HD10U?. Hmmm I know I asked over and over again. I don't have $$ and I don't want to waste it on a camera that will not work right for me. The camera will be for shooting movie/ home movie...wedding
Som Xai is offline
Old January 6th, 2004, 02:53 PM   #11
Oh with the JY-HD10U, can I still use my Avid Express and Adobe Premiere Pro software to edit the footages?. or do I have to purchase additional editing software for it?.
Som Xai is offline
Old January 6th, 2004, 02:57 PM   #12
MPS Digital Studios
I understand Avid stopped by JVC's factory last November. This is from Ed Sherry at JVC.
heath
Old January 6th, 2004, 03:30 PM   #13
<<<-- Originally posted by David Kennett :
If anyone has a place to post it, I could make a short DVD compliant MP2 file with some samples. -->>>
Dave, I have a server you can use to host those files (e-mail address is in my profile).
"Oy... Aim it downhill."
Andres Lucero is offline
Old January 6th, 2004, 10:18 PM   #14
Barry Wan Kenobi
<<<-- Originally posted by Christopher C. Murphy : If you shoot in HD - then downconver it to SD - you will have a better image than something aquired in SD. -->>>
That's only if all other things are equal, and in this case they're definitely not.
The HD1, a base-level consumer camera (although with HD resolution) cannot be compared to the XL1, an outdated but once premium 3CCD camera. If they were comparing a consumer 1-chip DV camera against a consumer 1-chip HD camera, hence all other things being equal, then your statement would hold correct.
Again, this very question (or a strikingly similar facsimile of it) was addressed by JVC on their HD1 FAQ. The question was "how does the HD1 compare to a top NTSC 3CCD camera" and in their answer they acknowledge that the 3CCD camera would have better latitude, color rendition, saturation, etc.
Old January 7th, 2004, 09:20 AM   #15
<<<-- Originally posted by Barry Green : <<<-- Originally posted by
Again, this very question (or a strikingly similar facsimile of it) was addressed by JVC on their HD1 FAQ. The question was "how does the HD1 compare to a top NTSC 3CCD camera" and in their answer they acknowledge that the 3CCD camera would have better latitude, color rendition, saturation, etc. -->>>
I hope you aren't referring to this quote from the JVC HD1 FAQ page:
Would 3 CCDs be superior to 1 CCD?
For absolute picture quality, yes. But there are practical trade-offs. 3 CCDs would provide superior accuracy of color reproduction, and would provide superior resolution for same density of CCD. However, the 3 CCD camera would be larger, heavier and draw more power which requires a larger battery. The 3 CCD camera would, also, increase the price of the unit.
If you are then you seriously misinterpret it. JVC makes no mention of NTSC. They are commenting on 3CCD vs. 1CCD technologies at the same resolution. You cannot reach your conclusions from this. Furthermore, a FAQ is aimed at nontechnical readers and is not always rigorous. They did not mention "latitude, color rendition, saturation, etc." either. They said color accuracy and resolution (which I personally interpret to be sharpness).
Without arguing the merits of the XL1 vs. the HD1, I'll point out that the HD1 in HD mode has far more chroma bandwidth than any DV camera possibly can.
It was once claimed by laserdisc lovers that DVD could not possibly approach the quality of laserdisc "because it was compressed and laserdisc was not". Ignoring the fundamental ignorance of that argument, it has been shown to be untrue. I believe we have an analogous situation here.
Craig Jones is offline
  You are here: DV Info Net > And Now, For Something Completely Different... > The Archives > JVC GR-HD1U / JY-HD10U
