is HD10 compatible with FireStore ? at DVinfo.net
Go Back   DV Info Net > And Now, For Something Completely Different... > The Archives > JVC GR-HD1U / JY-HD10U
All about the original single-CCD HDV camcorders from JVC.
Old November 23rd, 2003, 12:45 PM   #1
Anybody know if the direct to disk system 'FireStore" works with the JVC?
-Les
Les Dit is offline
Old November 23rd, 2003, 01:39 PM   #2
Moderator
Not in HD mode. It may be compatible in DV mode.
The FireStore is for 25megabit DV only so far.
Perhaps Matt can expand upon this soon.
- don
DONALD BERUBE - noisybrain. Productions, LLC
Director Of Photography/ Producer/ Consultant
http://noisybrain.com/donbio.html
CREATE and NETWORK with http://www.bosfcpug.org
and also http://fcpugnetwork.org
Don Berube is offline
Old November 24th, 2003, 01:39 PM   #3
RED Code Chef
But isn't the HD stream encapsulated INSIDE a 25 mbps DV
stream? If so, it **might** work (not saying that it will!), right?
Rob Lohman, visuar@iname.com
Rob Lohman is offline
Old November 24th, 2003, 02:17 PM   #4
Moderator
Well, the frame structure is still very different. The bottom line is that if it is at all remotely possible, it would still require some form of system software upgrade to accomodate the unique file format of the HD10. That is one area where the FireStore interface stand out amongst the others, in that it the system software is user upgradeable, should Focus come out with an update. I think that is part of why the FireStore FS-3 is such a good investment.
The good news is that Focus Enhancements is very proactive in listening to comments and requests from all of the users out there. It's always nice to see Focus at all of the shows too, again they always make it a point to listen and take note of what the customers want.
Perhaps when the HDV format becomes more supported by the NLE manufacturers and when we start to see some real useable HDV cameras, then we may see it supported by FireStore as part of a future system software upgrade.
- don
Old November 28th, 2003, 09:25 AM   #5
<<<-- But isn't the HD stream encapsulated INSIDE a 25 mbps DV
stream? If so, it **might** work (not saying that it will!), right? -->>>
Not at all! HDV format uses an MPEG2 transport stream. This bears no relation to DV format other than the tape cassette used is the same.
Bob England is offline
Old November 28th, 2003, 12:12 PM   #6
Moderator
Yes Bob, agreed - as I stated in my reply, two different 'formats'.
The HD10 does also have the option to output DV via firewire - although I question why anyone would buy the HD10 just to use it as a DV cam. The only tangible merit of that camera is the capability to generate an HDV signal.
I spoke to Matt McEwan about this and we will be able to have an answer regarding whether or not any compatibility exists between the JVC HD10 and FireStore after the DV Expo West Expo in LA, which ends December 12.
Please do keep in touch,
- don
  You are here: DV Info Net > And Now, For Something Completely Different... > The Archives > JVC GR-HD1U / JY-HD10U
