Hidden service menus? - Page 9 at DVinfo.net
Go Back   DV Info Net > And Now, For Something Completely Different... > The Archives > JVC GR-HD1U / JY-HD10U
All about the original single-CCD HDV camcorders from JVC.
Old June 14th, 2006, 07:56 AM   #121
Originally Posted by Xander Christ
In furthering my investigation into this hacking project, a very knowledgeable JVC dealer told me that there have been modifications to the HD10U since its release. From trying to read between the lines of what the dealer was 'saying' without saying it (NDA?? He would neither confirm nor deny this), several hardware changes have been made without the model number changing. This would lead to different firmware floating around.
What sort of modifications was he talking about Xander?
Wayne Morellini is offline
Old June 14th, 2006, 08:08 AM   #122
As you can tell from all the posts, sorry for that, I have been re-reading right through the thread. One thing I came across, was the mention of a "change" etc manual for changing the firmware, did anybody find anything? That would probably describe all the useful locations.
Thanks for all your patience.
Old June 14th, 2006, 09:07 AM   #123
MPEG encoding engine is synchronous with frame rate. I am sure that inserting random black frames in MPEG stream is going to wreck havoc and significantly drop overall image quality. MPEG-2 compression relies heavily on interframe correlation, compressing only differences between new and predicted frame contents. But DV compression might be OK as each frame is compressed independently.
There is no easy place to tap into the digital stream as PCB has a range non-standard busses ranging from direct 10-bit data off the imager to data flow to and from MPEG-2 codec chip. All of it is synchronous data which also needs clock.
It looks like component Y'PbPr outputs have uncompressed signal on them and that's the best you can get - the component encoder is JVC's own chip and even then, it is in BGA package.
Leo Bodnar is offline
Old June 14th, 2006, 10:19 AM   #124
The component out is uncompressed, but it is at SD 60p. I have never been able to verify if it is the raw 1040x480 or if it is the condended 720x480 wide screen.
Damnit Jim, I'm a film maker not a sysytems tech.
Ken Hodson is offline
Old June 14th, 2006, 10:38 AM   #125
Capt. Quirk
Originally Posted by Les Dit
I'll bet the JVC HD cam has one lurking somewhere too. People should try powering up with all sorts of key combo's held down, it isn't that many possibilities and the rewards might be adjusting the ccd gain, and turning off/down the edge enhance on the HD1.
Who knows what else!
Who will be the first to find it? ;)
-Les
What does "Self destruct sequence activated" mean???
www.SmokeWagonLeather.us
K. Forman is offline
Old June 14th, 2006, 11:00 AM   #126
The dot clock for the D/A chip that produces component output is 27.75MHz. Given NTSC 60i video line timing is 51.2uS this results in 1420 dots per 60i line. I don't know timing for 60p signal but I assume it is roughly twice faster so it looks like 720 fits better.
Old June 14th, 2006, 03:37 PM   #127
Many people have reported that using their PD1's that their HiRes SD mode, captures at 1040x576, which is what the square pixel format is in wide screen, befor it is compressed anamorphically with wide pixels at 720x576. I would assume when you capture uncompressed (component out) you would get the raw widescreeen 16:9 SD which my guess would be 940(ish?)x480.
Old June 16th, 2006, 05:32 AM   #128
The image should never be worse, and hopefully better as it moves the data stream around to take advantage of the space freed up from a blank frame. But I see what you mean, it might make the mistake of saying that the blank screen has to be recorded as a difference from the last frame, rather then a big black rectangle, and the next frame the difference from the rectangle, inefficient. Some testing would be needed to see how smart it is in this. Even MiniDV can do this to a certain extent, even though it is inter frame, adjacent frames can carry extra data if some are left over (I read the specs).
The component out is uncompressed, but it is at SD 60p. I have never been able to verify if it is the raw 1040x480 or if it is the contended 720x480 wide screen.
Have you tried a res chart with a resolution synchronising monitor? Even a oscilloscope with a horizontal line pattern would tell (print lines, size to match expected camera resolution, see if it goes off on in sync) providing you have one of high enough sampling frequency.
Old June 16th, 2006, 11:57 AM   #129
I have never tried component uncompressed out from these cams.
Old June 21st, 2006, 02:55 AM   #130
Hi Leo,
I have totally disassembled my PD1... There are 2 PCB Boards. On the top, one named "Digital" with the Firewire connector, and on the bottom, one named "Analog". They are striped. Do you think we could get a Hi Def signal from this internal connection ?
My goal is to capture the raw data from the sensor and then apply a better demosaicing process. (I try to do the same thing with the Sony HC1)
How do yo connect your camera on a PC ? (cable pins and Software...)
Thanks.
Rodolphe Pellerin is offline
Old June 21st, 2006, 10:04 AM   #131
Good find Rodolphe. Brave, the problem I find in taking cameras apart is getting them back together in working order (my old sharp currently is not working and had some case circuit scheme that also seems to be at fault).
There is a guy that has experience with the HC1 firmware around, Wolfgang Winne, he is in Germany. It would be very good to ask him about this stuff in relation to the HC1, and you might ask him about the PD1.
http://www.dvinfo.net/conf/showthrea...035#post425035
http://www.schnellsuche.de/kostenlos...uAnleitung.htm
http://www.fxsupport.de/hc1/index.html
http://babelfish.altavista.com/babel...t.de%2F01.html
His static 35mm adaptor looks interesting.
http://www.fxsupport.de/hc1/hc1_9.html
Wolfgang is a very thorough person, like me, less the sickness, which you can tell by his site, he even looks a bit like me, poor lad ;) .
Actually, Juan from Andromeda, might also be interested. Not that it is worth doing for him, but maybe he might sell configurable recording units/software and let you figure it out.
Old June 21st, 2006, 09:56 PM   #132
Go Cycle
Actually, there are even more with the 5100....such as adjusting color rotation in EXTRA 3. AND.....hidden menu in the 3000 deck that allows LP as well as SP mode..........................................
Lou Bruno
Originally Posted by Christopher C. Murphy
Lou Bruno
Lou Bruno is offline
Old June 21st, 2006, 10:20 PM   #133
No easter eggs for the HD1/10. They should have to put at least one in by law!
Old June 25th, 2006, 12:05 PM   #134
Does any of this HD100 stuff help:
Menu and time-laps:
http://www.dvinfo.net/conf/showthread.php?t=68885
http://www.dvinfo.net/conf/showthread.php?t=70103
Old December 26th, 2006, 04:06 PM   #135
You probably misunderstood it. It can reallocate bits, but it won't use previous frames data to create a new one.
Inserting black frames into mpeg2 material will destroy the image quality. Like white flashes will create very nasty blocking.
Mikko Lopponen is offline
  You are here: DV Info Net > And Now, For Something Completely Different... > The Archives > JVC GR-HD1U / JY-HD10U
