Hidden service menus? - Page 10 at DVinfo.net
Go Back   DV Info Net > And Now, For Something Completely Different... > The Archives > JVC GR-HD1U / JY-HD10U
All about the original single-CCD HDV camcorders from JVC.
Old January 21st, 2007, 10:51 AM   #136
Originally Posted by Mikko Lopponen
You probably misunderstood it. It can reallocate bits, but it won't use previous frames data to create a new one.
Inserting black frames into mpeg2 material will destroy the image quality. Like white flashes will create very nasty blocking.
From memory that is what I read from the specs, that there is a limited portion of the frame data that can be given to the next frame (but maybe that was field).
With the black frame, as I said before, you might be right.
Wayne Morellini is offline
  You are here: DV Info Net > And Now, For Something Completely Different... > The Archives > JVC GR-HD1U / JY-HD10U
