I donīt have a HD display, but... at DVinfo.net
Go Back   DV Info Net > And Now, For Something Completely Different... > The Archives > JVC GR-HD1U / JY-HD10U
All about the original single-CCD HDV camcorders from JVC.
Old August 26th, 2003, 03:01 PM   #1
I donīt have a HD display, but I would like to have the extra resulution to work with in edit and post (pan&scan, and so on).
I am curius about the downconverting process: What does a downconverted image look like when viewed on a regular PAL televsion tube? ( HD -> DV ) does the downconverted HD it look better than odinary DV ?
(odinary) DV = 720*576 or
(JVC) HD =1280*720 downconverted (in cam) to 720*576
The question:
Is the "HD downto DV" nicer when viewed on a regular television tube? Or is regular DV better??
John Eriksson is offline
Old August 26th, 2003, 04:42 PM   #2
HDV Cinema
I'm unclear of your question. The JVC HD camcorders are NTSC only.
And your see your editing on an RGB monitor.
Steve Mullen is offline
Old August 26th, 2003, 05:01 PM   #3
Yes, you are absolutly right! But my question is:
Are the downconverted (JVC)HD nicer than odinary DV when viewed on a regular television tube right from the camcorders S-VHS port?
Or is the regular DV mode better??
..no matter where it is NTSC or PAL
Old August 26th, 2003, 07:54 PM   #4
Barry Wan Kenobi
Downconverted HD looks much sharper than normal DV mode.
Barry Green is offline
Old August 27th, 2003, 07:57 AM   #5
Thanks, that is great news!
  You are here: DV Info Net > And Now, For Something Completely Different... > The Archives > JVC GR-HD1U / JY-HD10U
