GZ-HD7U Warm Up
I have a HD7U camera that takes several minutes to warm up before I can start recording video, or even see something in the view finder.
Once the unit has been on a while I can turn it off then back on and there is no delay - its just when the camera has been off for a while that I have this issue. Is this normal? I have used other consumer cameras that are ready to record almost immediately after powering on. |
Hmmm
No one? I've tried an email to JVC Tech Support as well but no response there either.
Have not had the time to make a call yet. |
i don't think that is normal, mine is ready to go after about 5-10 seconds tops
Thanks for the input. I just wasnt sure as I had never used a hard drive camera before. Thought it might have something to do with getting the drives up to speed...
I guess I need to look at getting it serviced. |
#5 |
Warm-up time ~6 to 7 seconds to video clips
Just did a test using my iPhone as a stopwatch as follows:
Opened up the side screen Turned on camera and started stopwatch The "Enviro" portion kicked on and then the message "Select the desired mode" came up Hit the "Select Play/Record" button and then the thumbnails for the video clips came on. The whole process to this point was ~ 6 to 7 seconds. Could it be that the hard drive needs to be defragged??? Or are there a lot of files on it that could slow it down? |
#6 |
Formating
Think I tried formatting the HD already. Will try again when I get home.
#7 | |
I always do that. And when you see the message "Select the desired mode" u can use zoom out or in button, no need to go in "Select Play" mode, just hold for second zoom button, and that symbol will be disappear! |
