SD Cards and GZ-7 at DVinfo.net
Go Back   DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC Everio GZ-HD and GZ-HM Series
JVC's Everio Series 3CCD High Definition MPEG2 camcorders.
Old December 14th, 2008, 09:41 PM   #1
SD Cards and GZ-7
I shoot weddings and I use the GZ-7s for cover shots. I use the hard drives now but id like to start shooting to SD cards (for conveniance sake) Does the quality of the card matter? Do I shoot straight to the card? How much video will I get on a 8 gig card?
Randy
Randy Johnson is offline   Reply With Quote
Old December 15th, 2008, 08:02 AM   #2
A remark or a reminder: on the GZ-HD7, the video recording on a SD card can only be done in SP mode (1440x1080i VBR 19mb/s average), neither in FHD (1920x1080i VBR 26,6mb/s average) nor in HDV compatible mode (1440x1080i CBR 27mb/s).
If you are fine with this limitation, you can record around 52 minutes on a 8GB card in SP mode.
Bruno
(alias Koala)
Bruno Donnet is offline   Reply With Quote
Old December 15th, 2008, 02:28 PM   #3
Thats not a problem although can I shoot HDV compatable to the hard drive then copy it to the SD card within the camera?
Old December 15th, 2008, 02:43 PM   #4
Yes,
You can transfer in both sides (from HDD to SD , or from SD to HDD). See page 52 of your User Manual... ;)
Bruno
(alias Koala)
Old December 17th, 2008, 03:46 AM   #5
I forget to say that, if you decide to transfer a FHD or a HDV compatible video from the HDD on the SD card, the max time is around only 37 minutes for a 8GB card (it's because the video rate is higher for these 2 recording modes).
Bruno
(alias Koala)
Old December 20th, 2008, 09:57 PM   #6
Randy
I tried to record on SD card and quality was as good as Full HD, but I prefer to record video in HDD and snapshot in SD card! You may try 16GB/ 32GB card as well, those might will run!
Kaushik
Kaushik Parmar is offline   Reply With Quote
Old December 29th, 2008, 09:38 AM   #7
I thought 4GB SDHC Class 6 was the max this DVC will do.
Mark Cinense is offline   Reply
  You are here: DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC Everio GZ-HD and GZ-HM Series
