Everio and SDcards at DVinfo.net
Go Back   DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC Everio GZ-HD and GZ-HM Series
JVC's Everio Series 3CCD High Definition MPEG2 camcorders.
Old April 17th, 2008, 01:01 PM   #1
Everio and SDcards
I am thinking of getting 2 eveiros for cover shots for my GY-HD100s. I was planning on using the internal hard drive but I see they use SD cards too. Can they shoot video on those cards too or are they just for stills? Which Eveiro is best just for a static cover shot in a church? I do weddings.
thanks
Randy
Randy Johnson is offline   Reply With Quote
Old April 17th, 2008, 09:53 PM   #2
thanks
Randy
Randy,
Yes, you can record video too on SDHC cards, but camera allows you only 1440 x 1080 recording, you can not record 1920 x 1080. I have never use SD cards I always use internal HDD.
I have JVC GZHD7 and here is my profile on vimeo if you would like to see my posted videos: http://vimeo.com/user318721/videos
Kaushik
Kaushik Parmar is offline   Reply With Quote
Old April 18th, 2008, 07:15 PM   #3
Thanks. I want one to be a cover shot for a GY-HD100 in a 2 camera wedding ceremony the GY-HD100 only does 720p itself so I can use SP fine. Actually im going to need 2 I think for this application I can get away with the GZ-HD 3 unless you guys think I should opt for the 7?
Old April 18th, 2008, 07:37 PM   #4
Forget GZHD3, GZHD7 is the best, however you can consider new GZHD6 here is link: http://hdeverio.jvc.com/
Old April 18th, 2008, 08:11 PM   #5
What makes the 3 inferior image? Low light? Im only going to have it sit on a tripod and record a wide shot.
Old April 18th, 2008, 10:59 PM   #6
See here the differences between HD7 vs HD3:
http://camcorder.jvc.com/product.jsp...Id=141&page=15
And see here the diffrences between HD5 vs HD6:
http://hdeverio.jvc.com/spec.html
If I would be in your situation then I would have gone for HD6, becuse it is latest model and have some more features! Select HD7 or HD6, you will be happy!
Kaushik
Old May 6th, 2008, 07:16 PM   #7
I, too, shoot weddings. I feel the HD7's would accommodate your cover shots well. I also think they may come in quite handy elsewhere in the wedding shoot process.
Look to Cokin P series filters and lens hoods. Significantly more flexible the the original hood.
Waldemar
Waldemar Winkler is offline   Reply
  You are here: DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC Everio GZ-HD and GZ-HM Series
