GZ-HD7 and Avid Liquid 7? at DVinfo.net
Go Back   DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC Everio GZ-HD and GZ-HM Series
JVC's Everio Series 3CCD High Definition MPEG2 camcorders.
Old March 28th, 2008, 05:53 PM   #1
I can't find anything that says they're compatible, have they release updates to Liquid for direct import of the .TOD files? What's the workflow?
Alex Dunn is offline   Reply With Quote
Old March 28th, 2008, 09:34 PM   #2
HDV Cinema
Liquid work's fine with the HD7.
Old March 28th, 2008, 10:18 PM   #3
When you say it works fine... do I not have to convert the TOD files?? Does Liquid accept and use them? I'm buying this camera tomorrow if it does.
Old March 29th, 2008, 04:53 AM   #4
HDV Cinema
You need to change their extension -- a process than can be automated.
Old March 29th, 2008, 11:19 AM   #5
LOL... unbelievable. I can't believe they'd do that. You'd think compatibility would be a bigger selling point, I guess they need us to buy the archive station.
Old April 1st, 2008, 05:40 AM   #6
That is what the internet was invented for.
A simple HOW TO .TOD conversion to .mpg http://www.benzmodz.com/html/jvc_workflow.htm
Barry Smith is offline   Reply With Quote
Old April 8th, 2008, 04:04 PM   #7
Barry, the page you posted mentions (not tested on 1440CBR). So you did test FHD, right?
The manual states "if you plan to export via iLink (firewire) you must use 1440CBR". But I guess that's not the case if you're grabbing the files directly via USB and renaming??
One test is worth a thousand questions, right!
Old April 8th, 2008, 05:53 PM   #8
HDV Cinema
You are correct. Moving files allows you to use FullHD. But, there's no real resolution difference between 1440CBR (HDV) and FullHD.
Steve Mullen is offline   Reply
  You are here: DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC Everio GZ-HD and GZ-HM Series
