Can HD7 use 8 gig or higher SD cards?? at DVinfo.net
Go Back   DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC Everio GZ-HD and GZ-HM Series
JVC's Everio Series 3CCD High Definition MPEG2 camcorders.
Old March 25th, 2008, 07:50 PM   #1
I just purchased an HD7 last night to use with my JVC 100a and I just downloaded Steve Mullen's excellent handbook. But as the thread stated, can you go past the 4 GB SD cards? I would like to shoot smaller ratio projects with the HD7 as a "B" camera to cards and keep personal projects, and documentation type shoots on the hard drive for later edit/archive.
Cheers, David
ps. Thanks Steve for the handbook.
David Parks: DP/Editor: Jacobs Aerospace at NASA Johnson Space Center
https://www.youtube.com/user/JacobsESCG
David Parks is offline   Reply With Quote
Old March 26th, 2008, 05:35 AM   #2
Cheers, David
Well come to JVC GZHD7 world! Congratulation for your new buy! I am using GZHD7 almost one year but I never insert card in it! But yours is good question, I was wondering that in some circumstances if HDD get failure then what we will do? If we able to use higher capacity SDHC card like 32GB or etc then we would be fine!
And I am not sure how much it will cost to replace the HDD and how fast we can do?
Kaushik
Kaushik Parmar is offline   Reply With Quote
Old March 27th, 2008, 06:46 PM   #3
" ... as the thread stated, can you go past the 4 GB SD cards?".
My guess would be maybe. The HD7 will likely get a firmware upgrade with the next model to handle bigger capacity SD cards. Hard and flash drive storage appears to be the touted feature of the next wave of camera models. Hopefully the firmware upgrades will be backwards compatible to the current HD7's.
Waldemar
Waldemar Winkler is offline   Reply With Quote
Old April 2nd, 2008, 05:54 PM   #4
HDV Cinema
Why not take your HD7 to Radio Shack and try different sized cards. They must be the correct speed for video.
Steve Mullen is offline   Reply
  You are here: DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC Everio GZ-HD and GZ-HM Series
