Uploading files onto Avid Adrenaline at DVinfo.net
Go Back   DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC Everio GZ-HD and GZ-HM Series
JVC's Everio Series 3CCD High Definition MPEG2 camcorders.
Old February 3rd, 2008, 06:45 PM   #1
I have recently bought the JVC GZ-HD7 but have had no luck uploading files into my Avid Adrenaline Mediacomposer. I have managed, for now, uploading without sound using the svideo connection but the through the firewire it doesn't want to know. Does anyone else on here edit on Avid?
Many thanks for your time. Here is the latest short film I have made. I am trying to document the street art scene here in the UK.
http://www.youtube.com/watch?v=DITxW3mcyGc
Jeremy Gibbs is offline   Reply With Quote
Old February 3rd, 2008, 09:59 PM   #2
HDV Cinema
Originally Posted by Jeremy Gibbs View Post
I have recently bought the JVC GZ-HD7 but have had no luck uploading files into my Avid Adrenaline Media Composer.
I use HD7 FullHD video with Avid Media Composer. (I really like Avid's color corrector!) Since you have yet to make this work combination work for you, can I suggest my HD7 Handbook.
Click to: http://home.mindspring.com/~d-v-c/GZ-HD7.htm
Old February 3rd, 2008, 10:52 PM   #3
Jeremy, I can lend testimony to Steve's handbook. I bought it recently and it is great. He explains tons of info thoroughly and eloquently. Well worth the 30$.
Ray Grizzle is offline   Reply With Quote
Old February 4th, 2008, 08:13 AM   #4
I have the book already. Do I need Avid Liquid 7.2 on my Avid Adrenaline to import any files from the camera. Just want to be certain before I spend anymore money.
Thanks for your time.
Old February 4th, 2008, 05:26 PM   #5
HDV Cinema
If you mean IMPORT FROM FILE -- go to the Editing Workflows Chapter and the section Indirect Clip Use. This will tell you how to import files from an HD7. Then scan down to Decode and Compress to DNxHD.
You can create a 1920x1080i60 Project in which to import your DNxHD clips.
Old February 4th, 2008, 06:56 PM   #6
I don't know if I do mean import from file. Sorry, really not very computer literate. I have shot some HD on my JVC camera and have also burnt some HD files onto the CU-VD40 DVD burner. I now want to import them into my Avid Adrenaline but it is not letting me by using the firewire. But I can import it via the svideo link but without sound. Do I need more software?
I'm beginning to wish I hadn't bought this camera if I had known the problems beforehand!
Thankyou for your time.
Old February 5th, 2008, 12:53 AM   #7
HDV Cinema
Since you have a Media Composer you know that it can only import HDV via FireWire -- so you'll have to import files from the camcorder. The book gives you step-by-step instructions. So read the section on Indirect Clip use. Then, read the Decode and Compress to DNxHD section.
Below is an improved set of instructions:
After setting up batch import, use the "Export to other formats…" function. The Frame Size setting should be “1920 x 1080 (16:9).” Select QuickTime and click the Options… button.
Click the Settings button and choose the DNxHD codec. Now, set Depth to “Millions of Colors” and select the Resolution you want. Choose the "1080i/59.94 DNxHD 220 8-bit" or "1080i/50 DNxHD 185 8-bit" codec.
Click OK. Uncheck Prepare for Internet Streaming. Click OK. Click Save.
In Media Composer, create a New Project using "1080/59.94" or "1080/50." Now issue Tools > Media Creation.
Click the Titles tab.
Select DNxHD 220 MXF. Click the Import tab. Select DNxHD 220 MXF. Next, click the Mixdown & Transcode tab. Select DNxHD 220 MXF. Now, click the Render tab. Select DNxHD 220 MXF.
Now issue Tools > Import. Confirm the codec is DNxHD 220 MXF. Select the files and click Open.
Old February 6th, 2008, 09:34 AM   #8
Thanks for the time and information Steve. I will try that out.
You say I can only upload from the camera? Can I not upload from the files I have uploaded onto DVD's using the DVD Burner? Do hope so.
Old February 6th, 2008, 05:52 PM   #9
HDV Cinema
My bad. You are correct -- insert DVD and use it instead of the camcorder's hard disk. That's one of the really neat things about using the HD7 with the JVC DVD burner. It copies the whole file structure.
Send me an email and I'll send you a PDF of the new version of the Avid instructions. I tried them last night and they worked.
Old February 22nd, 2008, 10:26 AM   #10
hd3
are you going to modify the manual for the hd3?
Stanley Rivera is offline   Reply With Quote
Old February 22nd, 2008, 10:07 PM   #11
HDV Cinema
Since the HD3 has few functions than the HD7 there is really isn't much to learn. So you can read my HD7 book and ignore those functions you don't have
The editing functions are the same.
Steve Mullen is offline   Reply
  You are here: DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC Everio GZ-HD and GZ-HM Series
