Ls300 lolux at DVinfo.net
Old March 17th, 2018, 07:38 PM   #1
Ls300 lolux
I surrender. Everything I read in the manual says that lolux can be set at either ISO 12800 or 25600. I believe it but I can't find a menu item that allows these options. Can anyone tell me how to set lolux ISO?
Conrad Obregon is offline   Reply With Quote
Old March 18th, 2018, 03:57 AM   #2
Re: Ls300 lolux
I couldn't find it back either but why would you want that? 12800 allready looks bad, can't imagine how 25600 would look like.
Old March 18th, 2018, 07:55 AM   #3
Re: Ls300 lolux
Sometimes it's really dark and more important to get the shot, even if it really is noisy. But you are right; it really does look lousy.
Old March 19th, 2018, 08:17 PM   #4
Re: Ls300 lolux
Hi Conrad,
I only know of two ISO settings for Lolux, which are ISO 51200 and 25600. To make these changes:
Main Menu -> Camera Function -> USER Switch Set ... ->
keep scrolling down until you find "Lolux", and it will allow the option between 51200 and 25600.
[edit - info added] Looks like the difference between 51200 / 25600 and 25600 / 12800 depends on your Gamma mode. If you are in JLOG1, you will be restricted to 51200/25600. If you are not in JLOG1, you can set Lolux to 25600 or 12800. Hope this helps!)
Last edited by Steve Ritchie; March 19th, 2018 at 08:21 PM. Reason: Added new info.
Steve Ritchie is offline   Reply With Quote
Old March 19th, 2018, 11:11 PM   #5
Re: Ls300 lolux
"keep scrolling down until you find "Lolux", and it will allow the option between 51200 and 25600."
I found lolux but not the option to switch ISO.
Is there some other setting I'm missing?
Old March 20th, 2018, 03:50 AM   #6
Re: Ls300 lolux
I just checked on my camera and I was able to see and select the different max lolux iso's.
Old March 20th, 2018, 07:12 AM   #7
Re: Ls300 lolux
Oops. My bad. I stopped at user 3 which is set to lolux. I finally realized I had to continue down the menu for the lolux button. Thanks to all.
