External monitor question at DVinfo.net
Old January 12th, 2018, 12:16 PM   #1
I will be using the LS300 next week shooting 1080/50P to the internal cards.
Do I have any options on setting the BNC monitor output? That is, will it be identical to the recording format at 50P or can that be changed to something else?
I ask because my monitor may not accept 50P, only as 50I.
"the difference between an amateur photographer and a professional is the amateur shows you all his pictures"
George Odell is offline   Reply With Quote
Old January 12th, 2018, 06:47 PM   #2
Re: External monitor question
Maybe do some testing?
Scott Berrington is offline   Reply With Quote
Old January 13th, 2018, 06:07 AM   #3
In a perfect world I would but the client, a foreign national, is supplying the camera the day of the shoot.
My understanding is, if shooting in 4K you can have the external BNC downconvert to 1080I, but I cannot find anything in the manual that says you can change that output to anything else if shooting only in HD.
Just hoped someone who owns the camera had had the need to do something similar.
Old January 13th, 2018, 07:00 AM   #4
If recording in 1080 50p, you have the option of setting the BNC output to 50p or 50i.
Old January 13th, 2018, 10:06 AM   #5
If that's the case, then I'm all set. I can use my monitor on 50I and shoot at 50P.
Much thanks.
Old January 19th, 2018, 04:46 PM   #6
yes, you can set it to 1080 50/60i for SDI and HDMI
Lawrence Kong is offline   Reply
