#16 |
Re: Editing 4:2:2 without conversion?
Question: Does everyone find the new update for 4:2:2 workflow worth it at 4K? I've only just barely had time to test it a little while shooting at some mixed primary color still life so I haven't done enough to make an opinion. Not having C4K but 4K UHD format is not a deal breaker... and FCPX seems to play the 4K 422 footage fine. But being 8 bit not 10 bit 422 instead of 420 didn't leap off the monitor on curved reds or seem to have much more leeway in post. But I've only shot 5 minutes of footage just to make sure the firmware update worked. Does anyone have a 420, 422 8 bit comparison they have done that shows it off? (thinking stills full sized png or something would be great)
Thanks |
#17 |
For me, it hasn't changed the workflow at all, so I'd say it's well worth it. I still edit straight out the camera.
I've never really understood why someone wouldn't use the absolute best settings in camera. You can't cut a piece of string longer, so its better to start with too much right? 4:2:2 is a lot more colour than 4:2:0, check this video out for better info: Then the whole 10bit, 8bit thing - 8bit grades fine, just don't push it. No one in the real world will ever tell if you're footage was 10 or 8bit unless you're overdoing the grade. Hell some of the grades on Canon DSLRs 10 years ago looked amazing, but no one was talking about it at all then. Of course, as I said above, if your camera can shoot 10bit 4:2:2, then go for it, but I think the GH5 has made people obsess over things that don't really matter. For example, the movie 'Tangerine was shot on an iPhone 5s and looks amazing despite that. |
#18 |
Does anyone know if this re-wrapping to MXF has been tried with Panasonic's 10-bit 422 files by anyone?
Chris Young CYV Productions Sydney |
#19 |
On the Mac side, EditReady may cover this problem. You can download a demo and see if that helps.
William Hohauser - New York City Producer/Edit/Camera/Animation |
#20 | |
#21 |
#22 |
#23 |
I took a look at EditReady for Mac and it only supports MXF as an input file format. The Rewrap function within EditReady only outputs .MOV and JVC 422 files are still not recognized after rewrap.
There are other programs for Mac that I will investigate as the earlier mentioned ffmeg solution contains .exe files that only make it suitable for Windows users. If anyone is using a Mac program to rewrap MOV to MXF, please let us know. |
