VSM vs. Speedbooster at DVinfo.net
Old April 5th, 2016, 11:47 PM   #1
So I tried using my SB with my old Nikon primes and hoped that there was enough sensor coverage to keep the VSM at 100% and still take advantage of the extra f-stop. Unfortunately to get rid of the vignette I had to set it to 92%.
Would it be better to use a normal adapter to avoid image scaling and stay at 100%? Or would you have to pixel peep to see the difference between 92% and 100%. I won't be able to do any of my own testing for a few days- but wanted to see what other owners thought until then.
=^_^=
Ed Kishel is offline   Reply With Quote
Old April 30th, 2016, 04:09 AM   #2
Images: 10
Re: VSM vs. Speedbooster
92% sounds pretty good. I expect your speedbooster is only designed to cover a micro four thirds sensor.
If you look at this page: Metabones® you can see that Metabones recommend a setting of 86%.
What SB do you have by the way?
I'm in the market for new lenses and maybe an SB too, but I think that having to set the VSM down to 86% almost negates the SB's affect on the focal length, although the additional light gathering will still be useful.
Duncan.
Old April 30th, 2016, 12:08 PM   #3
Rokinon 35mm and 85mm T1.5 primes can handle the 0.7x SpeedBooster at 100% VSM without vignetting.
Lee Powell is offline   Reply With Quote
Old April 30th, 2016, 02:18 PM   #4
Images: 10
In that case you'd expect all the Rokinon Full Frame lenses to do the same or similar...
I really think I should buy them.
Duncan Craig is offline   Reply
