Jib Stand? at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Jibs / Cranes / Booms
Old June 17th, 2007, 08:23 AM   #1
Jib Stand?
I'm looking for some kind of stand I can rest and secure my JonyJib on. This stand would also be very helpful when assembling the jib arm.
Anyone have any suggestions or seen anything that might work?
Myrtle Beach SkyTour http://www.myrtlebeachskytour.com
Ralph McCloud is offline   Reply With Quote
Old June 19th, 2007, 06:18 AM   #2
how do you secure your jib arm?
How are you securing or holding up your jib arm? I'm looking for a solution to rest the jib arm on while setting up, etc. anyone?
Old June 20th, 2007, 07:32 AM   #3
Kessler sells a clamp mount that attaches to a c-stand;
http://www.kesslercrane.com/index.ph...=20&Itemid=41#
(scroll down a ways)
I'm still "crane-less", so no actual experience, although a Bogen super clamp/c-stand might have some possibilities... Steve
Steve Leverich is offline   Reply With Quote
Old June 20th, 2007, 01:25 PM   #4
still looking
Thanks for the info, but I don't think that's going to work for my jib arm. I need something more like an "upside down horseshoe" shape to cradle the jib arm.
Old June 23rd, 2007, 12:02 AM   #5
I use a 5 ft folding aluminum step ladder that I purchased from Home Depot.
It has a plastic covered top step that has a holder tha I can put small items like bolts in. The tip of the jib arm rests perfectly on the top step. ( I use the EZFX jib.)
Allen Williams is offline   Reply With Quote
Old June 27th, 2007, 01:08 AM   #6
Use a speaker stand and make a yoke with 1" pipe that fits into the stand. You'll need something like 3 6" lengths, 2 nipples, a tee, and (2)elbows. You can cover the pipe with insulation to make it a nice and soft landing. Or on the cheaper/lighter you can use 1"dowell/closet rod and one of those plastic coated bike hooks.
Charles Hurley is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Jibs / Cranes / Booms
