Mini jib for hand held operation at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Jibs / Cranes / Booms
Old December 7th, 2006, 08:38 AM   #1
Hello Jib/Cranes/Booms forum,
I have seen a set-up where the camera was mounted on a jib yet operated from the other end (i.e. camera end).
Does anyone know what you need to do this?
I assume it is a special setup with handles etc. I can see the advantage compared to a normal tripod in that you can 'pull' the camera around with you.
Can I get a 'budget' version anywhere?
Alex
Alex Wren is offline   Reply With Quote
Old December 7th, 2006, 10:23 AM   #2
Are you talking about the polecam? See http://www.polecam.com/Polecam.html
It seems to be more widely available and used in the UK.
JP
Jonathan Plotkin is offline   Reply With Quote
Old December 7th, 2006, 10:36 AM   #3
Hi Jonathan,
This is not quite what I had in mind although it does look quite interesting. I guess it is just a normal tripod mounted jib with a handle on the bottom of the camera mount.
I have since found something at http://www.b-hague.co.uk/Camcorder_Jib_Boom.htm which looks kind of what I was after (although possibly more expensive than I had in mind).
Alex
Old December 10th, 2006, 12:37 PM   #4
http://www.ezfx.com/
Ken Hendricks is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Jibs / Cranes / Booms
