Is it safe to use my tripod under this crane? - Page 2 at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Jibs / Cranes / Booms
Old January 15th, 2007, 08:11 PM   #16
Originally Posted by Allen Williams
Whenever you order from any mail order house,I would suggest to make sure they have a phone number that you can call to reach a real person... If you're going to use a Bogen/Manfrotto tripod and expect to extend the legs, get yourself a set (3) of Bogen Super Clamps.
Thanks Allen.
They finally responded. Turned out there was a problem with the shipping option I had selected. In fact the problem arose because I ordered the crane stand as well so as to avoid using the tripod. And the stand is larger than the allowable limit on a USPS parcel to Australia. Complications, complications...
The stand they sell is basically just an amplifier stand that I can probably get over here anyway...
John Hewat is offline   Reply With Quote
Old January 16th, 2007, 08:29 AM   #17
Speaker / Dj Stands to Support Kessler Crane
Just got my Kessler Crane delivered today.. nice .
A Manfrotto 116MK2 Fluid head is on it's way to support the Crane.
Adding up the total weight - Kessler =17lbs, Sony HVR Z1= 4.25 lbs, Counter Balance weights = 6.35 lbs. That totals 27.6lbs or 12.6 kg.
The Fluid head 116mk is rated for 22lbs.
I was told that such fluid heads are always underrated and this weight should be fine.
Now to the support issue .....
I have been looking at those DJ / Speaker stands that are rated up to 110lbs/ 50kg.
http://cgi.ebay.com.au/New-PAIR-of-P...QQcmdZViewItem
Does anybody have any experience with such stands ?.. and if so how would one attached / secure a fluid head to the top?
Apparently its a 35mm diameter on the extension tube.
Stability / strength ? / the spreader is low ..
Ming Darcy is offline   Reply With Quote
Old January 16th, 2007, 03:06 PM   #18
IF those stands will support a speaker they should be plenty sturdy enough for a crane - I've not done this yet (still scheming :=) but if you don't have access to a welder, I'd consider getting something like this
http://www.stagebeat.co.uk/index.php?page_id=266
and making (or having made) a bracket that will bolt to the speaker socket and having the 3/8/16 thread mount that pro tripod heads use, so you can adapt your head to the speaker socket.
From what I've found so far, in actual practice you don't NEED a fluid head on a crane, because the inertia of the weight of camera and crane does enough to smooth out camera motion - this would let you move your fluid head to the CAMERA end of the crane so you can use it in yet another mode - check out some of the videos here
http://www.kesslercrane.com/index.ph...d=53&Itemid=36
Here's another site with pix of the head being used at the other end of the jib
http://www.ezfx.com/index.php?option...ask=view&id=21
Kessler also makes a machined tripod head replacement (works with ball mount tripod sticks) that's stronger than most expensive heads and still allows moving YOUR head to the camera mount plate of the boom.
HTH... Steve
Steve Leverich is offline   Reply With Quote
Old January 16th, 2007, 04:16 PM   #19
Thanks Steve,
Which one of the two would you modify ?
I'm a bit worried the moulded PLASTIC (180.178 SPEAKER STAND EXTERNAL MOUNTING ADAPTOR) might strain / crack under the weight of the crane.. and with the stress of the head.
The METAL (EBH53 SPEAKER STAND TOP HAT INSERT) .. does has it enough surface area on the top to distribute the load ?
thanks Again ..
Old January 17th, 2007, 11:41 AM   #20
The ones made by Ultimate Support
http://www.bhphotovideo.com/bnh/cont...ughType=search
are of carbon fiber and rated to 100 pounds - also these stands
are rated to 100 pounds - I'm still looking for a wide-stance dolly with big wheels and full locks, may have to do some serious mods for that part.
For the adapter (first link) I would use that adapter on the crank-up stand, and make a steel plate of 1/4" flat stock that was the size of the socket adapter (no dimensions are given so far) - I would drill and tap 3 holes in this plate, one in the center for a 3/8 x 16 thread bolt to attach the Kessler fluid head to and two more (probably 1/4-20 thread which would be used to fasten the adapter plate just described to the speaker socket adapter.
IOW, from bottom up it would be the crank-up stand, the socket adapter, the home-made plate with 3/8 tapped hole in center, and Kessler's ball mount adapter -
http://www.kesslercrane.com/index.ph...id=7&Itemid=40
onto which I would mount the Kessler 8/5 foot crane (til I need a longer reach)
I would use this setup nearly ALWAYS with a fluid head mounted at the camera position, so you can lock the cam/boom in place and use the setup in a more "normal" way, or simply release the locks and use it in boom mode and as a jib.
As I said, this is an ongoing project for me - but hopefully someone can benefit from my inane meanderings... Steve
Old January 18th, 2007, 08:57 AM   #21
Nice looking combo..
The carbon adapter head and plate combo beginning to look good.
It seems the 38mm diameter is pretty much standard on most stands.
Manfrotto has a large range of lighting stands and heavy duty support products.
Found a m12 adapter (611-12) on
http://www.manfrotto.com.au/Lighting...b_Cat_Code=120
Not as strong as your carbon number from B-H though ...
check out these stands with wheels...
http://www.manfrotto.com.au/Lighting...b_Cat_Code=130
The B200 looks pricey ....
Old January 18th, 2007, 09:13 AM   #22
Seen these DIY dollies ?
PIcs od DIY dollies...
http://homebuiltstabilizers.com/greydollies.htm
still no crane on top....
Old January 18th, 2007, 09:57 AM   #23
Found one of those at B&H -
http://www.bhphotovideo.com/bnh/cont...goryNavigation
Generally for lighting, goes from about 6 to 12 feet. $600, and only supports just under 20 pounds. Guess it's back to the speaker stands - 5 times the weight support and 1/5 the cost - at that rate, for a penny we should be able to support 12 tons :=) (also, wrong size mount on top of the manfrotto unit, you'd need to find a different adapter to fasten the crane to it.
Some pretty cool projects shown on that other link, thanks... Steve
Old January 18th, 2007, 03:18 PM   #24
If you want a serioius dolly with wheels and locks that will fill all your expectations including adjustable height that will clear any one sitting down when you're in a tight spot,
consider the EZFX pedestal. It's a bit costly but when it comes to safety this is the real deal. The pedestal is easy to set up and you can easily raise the base to well over five feet with no loss of stability. I have used it on inclines using auto screw jacks to keep it level.
I've use it during church concerts where because of space limitations, the jib is flying over the heads of people sitting in pews a few feet away. Each wheel is seperately able to lock in place in addition to individual wheel locks. The base has a low clearence that is able to slide under obstructions such as seats. I use a full size camera with pan & tilt head and around 100 lbs of weight. Construction is solid with no torquing because of its design. It's worth every dollar invested.
Allen W
Allen Williams is offline   Reply With Quote
Old January 18th, 2007, 09:41 PM   #25
Allen, thanks for the suggestion; seems like those run about $1500 - not bad for a pre-made, no DIY needed solution (especially if you need the low profile for sliding under benches as you do) - but for my needs (more industrial oriented) I'll probably end up building a dolly and buying the crane.
Thinking now about a center "spider" to allow all 3 legs to fold together (kind of like a tripod top only simpler), then each horizontal leg would be made of a section of 1-1/4" and a section of 1" .095" wall square tubing, nested inside each other like an auto jack stand - I'd weld plates on the outer ends to fit these
http://www.woodcraft.com/family.aspx?FamilyID=1989
(the "B" style in 5")
Then, on the top of each leg where the caster goes, a "U" bracket to allow a custom socket to swivel a bit, drill a hole in each leg of the speaker stand for a locking pin, and I should have a collapsible, transportable dolly/crane that fits easily in my van and goes together fairly quickly.
So far this is all just "brain farts" (haven't started any CAD drawings yet) but when I do, I'll post basic drawings for anyone who's heavy enough into DIY to have access to a welder - I think I can build this (including casters, speaker stand, adapter, MINUS the crane) for around $200-250. (Probably a bit more if I want it powder-coated, I don't have this ability in my shop yet)
It'll end up with about a 48" diameter footprint, adjustable down to probably 36" with lower pedestal heights, and the dolly should weigh around 30 pounds including casters (a VERY rough guess at this point)- it could be made lighter if I were advanced enough to have a TIG welder and the ability to weld aluminum, but it'd also cost more in aluminum.
I'm not sure how soon I'll get started on this, I'm pretty much buried in paying projects ATM - but when I do, I'll start a new thread here with enough details for an experienced DIY type to be able to duplicate/improve it... Steve
BTW - this
http://www.doityourself.com/invt/u505412
is what I'll be using for tying things together - a simple, no-tools approach. If you spread the semi-circular locking spring it pops off the end of the pin so it can be inserted in a hole - these come in several sizes, and to keep rattles to a minimum you can open the locking spring and slide a short piece of either light weight clear plastic tubing over the spring, or a piece of electronic shrink tubing will also work. (Just a "teaser" for anyone who wants to get started instead of waiting for me to do it :=) Steve
  You are here: DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Jibs / Cranes / Booms
