Jib tilt and lean at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Jibs / Cranes / Booms
Old October 5th, 2005, 02:20 PM   #1
Jib tilt and lean
I have a problem that arises on regular occasion when using my crane.
The crane is made to tilt up and down by utilizing the tripod head where the crane is mounted. I've noticed that if I only do purely vertical moves everything is fine, but if I pan and tilt the crane simultaniously the claw ball that mounts the head to the tripod will slide and become unleveled, which obviously results in shots that end up leaning strangely.
I've also tried mounting the crane directly to the claw ball, but the same results occur. Anyone out there having similar problems? I'm using a heavy duty all metal head from gitzo mounted on a set of gitzo legs, this is definately not an issue due to using a DV tripod head. Any ideas of what could be causing this?
Rick Pearson,
http://www.nextlevelmediaproductions.com
Rick Pearson is offline   Reply With Quote
Old October 5th, 2005, 02:33 PM   #2
What kind of crane is it and can you provide any close up images of the fulcrum or wherever it's doing this when it's in service?
James Emory is offline   Reply With Quote
Old October 5th, 2005, 02:43 PM   #3
it's a cobra crane II, and I don't have any images. But if you use your imagination to put yourself directly behind the crane as its mounted on the tripod and balanced perfectly... you would see that it's not sitting level from side to side. The legs are leveled, but the weight of the crane applied to the head, or the ball alone has caused it to lean to one side. I don't know if this helps, but that's the "picture".
Rick Pearson,
Old October 5th, 2005, 02:48 PM   #4
Well, I have a full size Jimmy Jib that has similar issues. It has a rubber O ring between the fulcrum and the plate that attaches it to the tripod. Either the bolt is slowly loosening and creating a bigger gap between those two pieces allowing more play, the O ring is becoming compressed allowing the play or both. The reason I need to see picture is I don't know what a claw ball is.
Old October 5th, 2005, 03:22 PM   #5
Here is a product that utilizes the ball I was referring to. In the description it is listed as a 100 mm ball base. It's merely a half ball that allows easy leveling of the tripod head by loosing and tightening a knob underneath the point of head attachment on the tripod.
http://www.bhphotovideo.com/bnh/cont...ughType=search
Rick Pearson,
Old October 5th, 2005, 03:27 PM   #6
Okay. I'm familiar with the ball leveler but had never heard it called a claw ball before. Are you sure that it's designed to handle that much weight or weight that is distributed in that way? If your system has that hi hat, riser then the center of gravity is going to be top heavy and cause that leaning. If this is the case, that is not safe! If you don't have that riser, I bet that ball is slipping in the bowl because it's not designed to be used like that.
Old October 6th, 2005, 12:39 PM   #7
No, I don't use the high hat or anything like it. I utilize an all metal high end fluid tripod head from gitzo. The leaning is coming from the ball element, but in my attempt to be sure and take the head out of the equation I did try mounting the crane directly to the ball leveler. Some times it slips and leans sometimes it does not.
I used the crane today for over three hours on a location shoot and it performed perfectly, but just the other day it leaned. I am sure everything is mounted the same, and everything is tightened correctly... but for some reason it loses it's horizontal center of gravity on occasion and I was hoping someone here had experience with solving a similar situation. Thank you for your help and willingness to help in the matter. I do appreciate it.
Rick Pearson,
Old October 6th, 2005, 01:10 PM   #8
I can't figure out what it could be without seeing pictures of the rig as you have it configured. Can you take some pictures of it at the fulcrum and joining points in both configurations? I'm not really familiar with what a Cobra looks like. Is the head seperately adjustable from the arm. Mine is and you have to adjust the side to side to level after you have leveled the fulcrum.
Old October 6th, 2005, 01:14 PM   #9
Yeah, I'll get some pics. Today's shooting schedule was overly busy so I didn't take any setup shots this time around, but the next shoot I'll snap a couple stills and throw them up, I don't know when that will be though. Thanks.
Rick Pearson,
  You are here: DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Jibs / Cranes / Booms
