best portable jib. at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Jibs / Cranes / Booms
Old June 27th, 2012, 09:19 PM   #1
best portable jib.
the new trapezist portable mini jib by light craft workshop looks great. However, I want to know what are my other option. What other portable jibs do you guys know?
Victor Nguyen is offline   Reply With Quote
Old June 27th, 2012, 09:48 PM   #2
Re: best portable jib.
There's the Aviator jib on Kickstarter, looks pretty cool to me.
The Aviator Travel Jib by Nice Industries — Kickstarter
DSLR Photographer/Videographer from Massachusetts
Portfolio at http://ebourcier.com
Evan Bourcier is offline   Reply With Quote
Old June 27th, 2012, 10:46 PM   #3
corrections. What I mean by portable is that I can set it up in 3-5 minutes
Old June 28th, 2012, 12:02 AM   #4
Aviator jib looks good! I have the DSLR-devices jib, I love it but the 2piece structure does post some logistics issues. The Aviator has it all in one structure. I would mod the weights portion like the DSLR devices. That way the crane can be perfectly balanced.
The lightcraft trapezist is a combination of the DSLR devices and Aviator jib. The launch price of USD299 is really a steal!
Firewerkz Films SGP
Old June 28th, 2012, 07:05 AM   #5
The trapezist portable mini jib does look good at a very reasonable price. I think the lighter the camera the better on this rig. I have the glideshot 4 foot jib. It is not very portable for backpacking as the trapezist but it can hold a little more weight. With any lightweight jib "bounce and wobble" are not your friends. It takes a fine touch and lots of practice to eliminate this. Wide shots and not extreme closeups will look the smoothest. With heavier more rigid and expensive jibs this is usually not an issue and that is what you are paying for.
Old September 11th, 2012, 08:53 AM   #6
Not sure if this suit you, I got one last week and it works like a charm.
Products ‹ Gear Contact Ltd
Madison Lee is offline   Reply With Quote
Old September 16th, 2012, 03:57 AM   #7
I'm a big fan of the seven jib. Lightning fast setup and able to support a large camera rig like a Red. I've reviewed here here on dvinfo's forum in the past.
Andrew Dean is offline   Reply With Quote
Old October 18th, 2012, 08:39 PM   #8
I have this ifootage mini crane too, absolutely worth the $370USD for a carbon crane which weight for 1.5kg only. But you will need a very light camera.
Thomas Wong is offline   Reply With Quote
Old November 9th, 2012, 09:52 AM   #9
For anyone interested, here's a review we just did of the Trapezist, hope you like it :)
*** Click "CC" for English subtitles
Iker Riera is offline   Reply With Quote
Old November 9th, 2012, 10:58 AM   #10
You guys sure love LCW
Old November 9th, 2012, 02:47 PM   #11
we like to stick with brands that have worked for us in the past, at least until some better option comes along.
Old November 9th, 2012, 03:27 PM   #12
Iker,
is this Trapezist jib smooth and stable, do they use bearings, or there just drilled holes in the tubes?
I love this place!
Old November 9th, 2012, 03:38 PM   #13
They use drilled holes in the tubes and base.
The vertical movement is pretty smooth and steady once balanced, but the horizontal movement relies on the tripod head that you use, so that part of it's performance varies from user to user.
  You are here: DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Jibs / Cranes / Booms
