Crane rotation speed? at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Jibs / Cranes / Booms
Old April 29th, 2010, 08:50 AM   #1
Hi!
We have a crane/dolly being built by local engineering students as a semester assignment. They ask us about maximum rotation speed of the crane head. We don't know really. Can anyone help?
Jiri Fiala is offline   Reply With Quote
Old April 29th, 2010, 03:27 PM   #2
Images: 18
Hi Jiri.............
You might get some usefull info here:
Pan & Tilt Rigs
The fastest (of those that bothered to list it - an awefull lot don't) was 210 degrees per second.
That's one serious whip pan.
Others I found were 90, 90, 45, 15 & 9 degress per second.
Personally, I'd say 120 degrees per second would be as fast as you'd ever realistically want to go, that's a full circle in 3 seconds, enough to make you throw up your breakfast.
CS
Old May 9th, 2010, 11:13 AM   #3
Hello Jiri,
I would not mind the speed this much as in 120 degrees a second is already fast enough for most shots.
I would be more worried of the fast starts and stops of both the rotation as well as the vertical movement.
an acceleration and deceleration can be about 6 m/s 2....
Good Luck,
Onno Perdijk
KeyGrip / Manufacturer
Solidgripsystems.eu
Amsterdam, Holland
Onno Perdijk is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Jibs / Cranes / Booms
