Jib - Anyone seen/used one of these? at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Jibs / Cranes / Booms
Old December 17th, 2004, 02:12 PM   #1
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=3859701787&ssPageName=STRK:MEWA:IT
Michael Best is offline   Reply With Quote
Old December 17th, 2004, 04:27 PM   #2
Have not seen or used one. According to the description, you can mount a "Broadcast" camera on it. Typically that refers to Beta etc. that can weigh 20-30 Lbs. If you did, you'll need a TON (maybe literally) to balance that thing.
Rob Wilson is offline   Reply With Quote
Old December 17th, 2004, 06:35 PM   #3
That doesn't seem like a bad price considering it's double the length and stronger than that of most jibs in its class (without remote heads) and can fly larger camera systems. Just put a remote head on it and it will be on it's way. I would be very interested to know just which national shows that it has been used on.
James Emory is offline   Reply With Quote
Old December 17th, 2004, 09:23 PM   #4
more detail here http://www.nuangle.com/nc1500.htm
from all the pics, the jib look a bit bend. do you think it can carry such heavy load?
this should be a good consideration too http://www.jonyjib.com/jonyjib.htm#JonyJib_18
ed
Ed Liew is offline   Reply With Quote
Old December 18th, 2004, 01:18 AM   #5
That's just it, I hear about a lot of bending with these smaller rigs. It does seem that the lower arm would have to help though.
Old December 18th, 2004, 02:25 AM   #6
very few jib of such lenght are design without the use of "cantilever". one such jib which i have the opportunity to use is the cammate travel series. it is very smooth and does not wobble at the end of the shoot. the construction is a big though.
ed
Old December 18th, 2004, 10:50 AM   #7
You ain't kidding about the NC 1500 looking like it's bending. That is not good. I hope the maker and end user have plenty of insurance.
Struts and cables would be a remedy for any vertical bending and/or horizontal swaying. That's what reinforces my 18ft jib. The additional pictures near the bottom of the jonyjib show it using a strut and cable configuration too.
The lower tie rod is mostly for allowing the head plate to maintain a horizontal position at any height even while in motion. When you exceed a certain length, you really need some more support like struts and cables.
  You are here: DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Jibs / Cranes / Booms
