Difference between HVR-M25E and the HVR-M25U at DVinfo.net
Old July 3rd, 2007, 01:35 PM   #1
Hello,
Does anyone knows the difference between a US version and the european version off the Sony HVR-M25E (DV-Deck).
It will save me a lot off money (more then 1000,- euro) if i will buy the US version through B&H and use a voltage converter.
And then the question: Why do you have in the US a prise that is more then 1000,- euro cheaper then in europe ?
Obed
Obed Boas Berg is offline   Reply With Quote
Old July 3rd, 2007, 02:21 PM   #2
perhaps dv mode is pal signal? maybe even hdv is 50hz? but then again here are the specs I found...(e-model)
HDV 1080i, DVCAM, and DV SP recording and playback
Compatible with mini-DV and standard size cassettes
Downconversion from HD to SD
Built-in 2.7" 16:9 "Clear Photo LCD plus" video monitor
Versatile I/O
HDMI Output
HDV/DV IN TC
Color Bar/1KHz Audio Tone
DUPLICATE PLUS feature
Edge Crop Adjust feature
MARKER BURN feature
Counter Set
Custom Repeat feature
Time Code settings
All Scan Mode
Assignable Buttons
1080i60 to 720p60 downconversion (analog component and HDMI outputs only)
60 / 50 Hz (NTSC/PAL) switchable
Multi-Language Menu
Carlos Rodriguez is offline   Reply
