Any video card with 3 outputs? - Page 2 at DVinfo.net
Old July 8th, 2007, 12:41 PM   #16
Apologies, and that is a mighty impressive setup I bet the clients love it.
Gregg Bond is offline   Reply With Quote
Old July 9th, 2007, 01:40 PM   #17
It was obviously designed to look impressive... :-) Adobe's Creative Suite apps all open pretty well across 3 displays luckily.
I did have one agency client who, between the huge display system, and the ability to eyedropper a color from the video picture for a title, now seems to think that the Avid house they had worked with is a little "mid-range"...
I just think that's so funny. It just goes to show what sorts of strange factors leave really long-lasting impressions on many clients.
TimK
Kolb Productions
Tim Kolb is offline   Reply With Quote
Old July 10th, 2007, 11:28 AM   #18
I'm sure it was on another thread on these boards, most times your average customer equates bigger to better.
They also think that TFTs are better than that junky old CRT in the corner but thats another story.
At the end of the day its not the tools though is it, the the quality of the work out the other end, and to have a setup like that I suspect your not half bad :)
Old July 19th, 2007, 02:04 PM   #19
Originally Posted by Tim Kolb View Post
Also...for the record, the Parhelia can do two DVI UI monitors and an HD video output OR 3 DVI outputs....
What Parhelia model are you using (or did you use?) Just for the record, have you ever connected a Parhelia like that? (2 DVI's and a HD mon?) or to 3 DVI outputs?
We're using the APVe and it doesn't seem to do that. It only will do one DVI with an analog, then the HD mon output on the other ouput. Either it doesn't do what you said, or we're missing something somewhere.
If the latter is true, please tell us how you connected it to the monitors and which PowerDesk version you used (HD or the new SE).
http://lightinaction.org
"All in the view of the LION"
Stephen Armour is offline   Reply With Quote
Old July 19th, 2007, 02:23 PM   #20
I went back and looked at the card (it is in between systems right now) and I realize that I was wrong...you're right. We had three VGA monitors on it for UI at one point...or it could have been one DVI and two VGA I suppose (1-DVI direct and 2 VGAs from the splitter).
I guess I was thinking about UI and automatically thought "DVI" and since I hadn't looked at the back of the card in a while (I only remembered it had DVI on the back and that we swapped out the component analog adapter for a third UI monitor at some point...), I got it wrong.
It's an APVe...and I'm terribly sorry to post erroneous information. I'm typically pretty careful about such things.
2 DVI outputs or:
1-DVI, 1-VGA, 1 Analog component
1-VGA, 1 VGA, 1 Analog component
1-VGA, 1-VGA, 1-VGA
TimK
Kolb Productions
Old July 20th, 2007, 09:11 AM   #21
Tim...I heart your studio!!
Can we get some specs?
Wade Spencer is offline   Reply With Quote
Old July 20th, 2007, 02:30 PM   #22
Well...the CPU is state of the art NAB 2005...a dual single-core Opteron 252, 3G Ram, AJA Xena LH, PNY Quadro FX4500 feeding a Dell 30" (top panel I paid 2200 USD for it when it first came out...ah well) via dual link DVI, and the Dell 24"-center panel via single-link DVI, a Quadro FX 540 (which I need to swap out for a dual DVI card one of these days) runs the two flanking 17" panels.
I have an 2 GB LSi fibre channel interface card in there that connects to a RAID system with two 6+1 RAID groups and a hot spare...15 250G drives. I was hoping for the 400G drives but when HD Sales in Chicago was getting this together for me, apparently MTV had purchased most of the available 400G drives on the continent for their ADTX units...so mine is populated with 250s as I didn't want to wait...I was cramming it in before the end of the year.
I have another 1.2 TB in nearline storage (3-400GB Seagate USB external drives) so I can keep some smaller projects backed up and I have a 3 250GB drive SATA RAID 0 inside the machine, which is nice for me as CineForm data is so damn efficient.
I'm an Adobe guy, so CS2 is on there...soon to be CS3. The Adobe packages lay out very, very nicely across the three monitors and it's nice to have all the resources "top layer" while working. My timelines are always on the 24".
I am an absolute Iridas convert so I have OnSet on my (also Dell) laptop and I have Speed Grade DI on the workstation which will go up to 2K and works VERY responsively with the 4500 display card. I use CineSpace to dial in the monitors (the 30" being the critical one as that one is overlay.)
While it's not in that shot, I have a better CRT than the one seen there...a BVM 14E5U (SD Broadcast standard monitor), which I use on the SDI output of the Xena card when I'm working on broadcast spots. Unfortunately Iridas can't use the AJA for video output, so I need to upgrade the 4500 to a 4500 SDI to view the CC output on anything outside of the calibrated 30" panel...
Other gear...
Convergent Design SD Connect
Convergent Design HD Connect LE
Canopus ADVC 500
patch bays for BNC, XLR, RCA, RS422 DB-9,...
SD WF/V
usually a bowl of midget Tootsie Rolls which, more often than not, I end up eating myself.
The furniture is built from limber yard countertops and believe it or not, the legs are car exhaust pipe...I got the client chairs on clearance at a local office supply chain store and the viewing deck was a great idea furnished by my friend Jerry Harvath (who also principally built it) when we were debating how I could utilize a roughly 13'x13'x13' cube of a room and give it some personality. By raising the room's table level to bar height (something I'm inexplicably drawn to...), it allows me 40" under the work desk to rack stuff, which is nice. I can also spin around and be face-to-face with the client around that table...
The thing on the wall is a curved surface (there's a symmetrical partner behind the camera) to attempt to "unsquare" the room a tad so it doesn't sound like a fishbowl. I have drop panels for the ceiling with completely indirect light ready to install...I just need the time.
The room is battleship grey and completely lit with daylight (6500 or D65) to help CC on the TFT, and there is no color in my forward view at all.
Other than wishing I'd integrated an ice chest into the client deck...I'm pretty happy with it.
TimK
Kolb Productions
Old July 21st, 2007, 07:20 AM   #23
...and Wes, before you "heart" my setup too much. It appears that the Tyan motherboard just went down for the count...
TimK
Kolb Productions
