Cineform AspectHD can't create m2t file at DVinfo.net
Old May 30th, 2007, 10:54 AM   #1
That's the message when exporting an HD movie to Cineform m2t file from PPro2. Download to Cineform AVI from XH-A1 is easy. Editing the AVI in PPro2 is easy. But exporting to m2t file aborts with cryptic message "Can't create m2t file" Won't create on any of my hard drives or RAID arrays.
Any suggestions?
ASUS p5wdg2 MB
Intel Core2 Duo 2.4GHz
2 Gigs RAM
XP current
2 Seagate SATA 500G for 1TB RAID array on Areca RAID controller
2 Maxtor SATA for boot, programs and other data
Rex Breeland is offline   Reply With Quote
Old May 30th, 2007, 01:41 PM   #2
CTO, CineForm Inc.
M2T export using the CineForm M2T export option is currently disabled under PPro2.0. You can use the Adobe Media Encoder instead, setting the format to MPEG2 and the Preset the HDV 1080i or 720p to match your target.
Old June 19th, 2007, 12:51 AM   #3
Hi
I have the same problem...When I export the m2t file via the adobe media encoder is the quality the same or not??
Best regards.
Fritz
Ffritz Arn is offline   Reply With Quote
Old June 19th, 2007, 01:47 AM   #4
Images: 1
I'd like to know as well.
BenWinter.com
Ben Winter is offline   Reply With Quote
Old June 19th, 2007, 08:31 AM   #5
CTO, CineForm Inc.
Both methods use the Mainconcept MPEG encoder, so the quality is the same.
Old June 20th, 2007, 01:11 AM   #6
Thank you very much for the answer David.
Old June 20th, 2007, 12:23 PM   #7
Hey David, out of curiosity...what's the reason behind this bug not having been resolved by now?
Not that it's a big deal, it's just a question that often comes up that Cineform have been aware of for a while. I imagine it must be a bug on Premiere's end more than anything, but do you imagine this will work by the time CS3 comes out?
Craig Irving is offline   Reply With Quote
Old June 20th, 2007, 12:30 PM   #8
Images: 1
Hmm...trying to export through Adobe Media Encoder gives me the same error message.
Any way at all to export m2t through CS3?
BenWinter.com
