HVR-V1U, 60i, 24A Capture and Conversion
Hi all,
I'm working on a project that currently mixes regular DV 60i footage with 24A HDV footage that I shot on a Sony HVR-V1U, as well as still graphics and LiveType titles. Any and all responses will be VERY appreciated! This project needs to be delivered on Friday morning. I followed this method to capture the footage: http://www.sundancemediagroup.com/ar...24P_HVRV1U.htm Here are the steps: 1. Capture and edit in native HDV 1080i60. 2. Once you’re done with the final render, select all on the timeline, then copy it. 3. Create a new sequence/timeline and set the QuickTime Video Settings, in the sequence settings, to Photo – JPEG and set the quality to 75%. Keep the frame rate/Editing Timebase to 29.97 fps/60i. 4. Paste the project into the new sequence, render, then go to File, Export, QuickTime Movie, but do NOT use QuickTime Conversion. 5. Once the movie is created, right-click on clip and select Cinema Tools. Go to Reverse Telecine and a window will pop up. 6. In Cinema Tools, you will need to find the “A” frame before you can begin. To find it, find the first frame of Interlacing, which looks like a “horizontal comb tooth” effect, if you will. Make sure this isn’t the very first frame of video; go in a second or two. Once you find it, go back two frames, and that’s the A frame. 7. Set Cinema Tools as follows: Capture Mode should be set to F1 – F2, Fields should be set to AA and Style 1, Conform to 23.98. Then click Okay. It will create a new movie that has removed the pulldown. 8. Import this clip into FCP and create another new sequence/timeline. Set the QT Video Settings to match the previous Photo – JPEG settings, quality at 75%. Change the frame rate/Editing Timebase to 23.98 fps. Put the clip in, render, then export. My questions are: 1) How do I handle mixing frame rates on the timeline? Do I need to delete the DV footage from the timeline that I'm going to make a QT file out of and reverse telecine, then add them back in on the new timeline afterwards? What about animated LiveType clips? 2) When I create the QT file, do I make it self-contained? 3) When I find the A frame in CinemaTools, does it need to be the A frame in the first clip? Will it effect things if many of the clips are very short and fast (5 seconds)? 4) Just to make sure, I only need to export the timeline as a QT and reverse telecine, not the individual clips, right? 5) What is the best method for exporting this at the highest quality without the capability of using BlueRay HD DVD's? Thank you so much! Any and all responses will be VERY appreciated. I have this project totally finished except for the CinemaTools steps, and the project needs to be delivered on Friday morning. Katie |
