Which HDV editing program do you use? - Page 3 at DVinfo.net
Old March 31st, 2007, 04:05 PM   #31
HDV -> HDMI -> capture into a new codec
HDV on tape -> HDV on disk -> software transcoding to new codec
Both involve 1 transcode. I guess there is an extra step in terms of time, but not in terms of quality.
Old March 31st, 2007, 04:20 PM   #32
Indeed. If I can do it in real-time and use that same interface for monitoring it's a win win.
-gl
http://www.motoxpress.com
George Loch is offline   Reply With Quote
Old April 2nd, 2007, 09:41 AM   #33
What are some codecs that can be used with the BMD Intensity card?
I know it comes with a JPEG codec, but I am not sure if that is the bast way to go.
If you had the choice between Cineform and BMD, which would you choose?
Jacob Carter is offline   Reply With Quote
Old April 5th, 2007, 12:48 PM   #34
Originally Posted by Harm Millaard View Post
There still is a lot of confusion about the value of HDMI. Look at the following figure to help you understand this. Double click it to get a readable size.
Pardon my confusion here – but is everybody talking about exporting via HDMI *after* being recorded to DV tape?
As far as I understand, once the signal is record to tape, it is compressed – and there is no going back. How then can you get an uncompressed signal (from the recorded tape) via HDMI if it has already been compressed?
Or perhaps I don’t understand this correctly.
Thanks --
James Binder is offline   Reply With Quote
Old April 5th, 2007, 01:05 PM   #35
Thanks --
You have it correct. The idea here is to take it from such a highly compressed codec (HDV) into a better post production codec in preparation for all the processing that happens in post and a codec that is easier to work with in terms of CPU overhead and accuracy.
Ideally, you would avoid HDV all the way but, next best option is to at least avoid it in post where there is a lot of work done to it.
-gl
Old April 5th, 2007, 01:53 PM   #36
Think of BMDs Jpeg option as the windows equivalent of the DVCProHD codec on the mac. It's very close in terms of data rate and quality so for most it will be very acceptable. OTOH the Cineform codec is a solid performer and since you can capture directly into Cineform via the BMD Intensity card you may be better off working in that space.
-gl
Old April 5th, 2007, 02:04 PM   #37
-gl
Thanks George.
So why not capture (from DV tape) via firewire with something like CineForm Intermediate codec?
What is the advantage of using HDMI?
Old April 5th, 2007, 02:07 PM   #38
There is none.
Old April 5th, 2007, 02:29 PM   #39
Thanks George.
The Intensity/Mjpeg codec offers a few advantages:
-You *can* bypass HDV compression by capturing directly to the computer via HDMI in either Cineform, BMD's utility or even PPro.
-In post, you can capture full-frame video (1920x1080) directly (Prospect HD can do this but at a higher cost).
-You can monitor via HDMI output to an HD Set in PPro.
I think the advantage is certainly greater for PPro and FCP users. For Vegas users, tell Sony to open up a standard architecture.
-gl
Old April 5th, 2007, 07:28 PM   #40
-gl
From a Vegas user: amen to that...
We're seemingly SOL in regard to BMD until Sony does so.
Old April 5th, 2007, 08:09 PM   #41
Final Cut Studio
I use FCS and it's great. I've never used HDV on my MacBook Pro, but I've done it on Mac Pro's and it works perfectly. It looks great to. If you have a mac or you can afford one, get FCS.
Nick Royer is offline   Reply With Quote
Old April 6th, 2007, 05:31 AM   #42
-gl
Can you explain HOW you can bypass HDV compression, when that is all you have on tape? On tape it is already HDV compressed, so it seems impossible to bypass it.
Old April 6th, 2007, 09:21 AM   #43
I didn't explain it well enough...sorry. I meant before it is recorded to tape. Capturing a live stream from HDMI.
-gl
Old April 6th, 2007, 09:44 AM   #44
My question would be then for field and nature videography is there a recommendation for a field hard drive that would record all this info? it is economical, uncompressed and better quality
William Boehm is offline   Reply With Quote
Old April 6th, 2007, 01:37 PM   #45
So far the most realistic option for capturing something less compressed than HDV in the field would be to use a Panasonic HVX200 with a Firestore hard drive, but that may not be realistic if you're recording many hours at a time.
Kevin Shaw is offline   Reply
