HD-SDI to ComponentVideo/AnalogAudio (and vice versa) at DVinfo.net
Old March 16th, 2007, 04:22 PM   #1
I am in the process of constructing a video editing and audio recording suite. I am looking for some help in the final stages. I'd appreciate any advice that anyone can offer.
My setup:
MacPro (running Final Cut Pro) with AJA Kona3 card (card has 2x HD-SDI inputs and 2 x HD-SDI outputs).
AutoPatch 16x16 switcher that uses Component YPrPb video (connected with BNC) and balanced analog audio (connected with XLR) -- with multiple SD and HD (1080i) devices attached for importing/exporting video and audio
I am looking for a way to complete this set up that allows me to use my 16x16 switcher with my MacPro via the Kona3 inputs (HD-SDI). Essentially I am wondering what my options are for connecting/converting HD-SDI video/audio to YPrPb video and balanced analog audio (and vice versa).
Any advice or directions on this? or recommendations based on your own current HD editing setups?
Thank you very much.
Lonnie
Lonnie Waterloo is offline   Reply With Quote
Old April 2nd, 2007, 10:44 AM   #2
here's the AJA converters that we've been using successfully on NLE systems and routers:
AJA HD10AVA $990
SD/HD Analog Composite or Component Video & 4-Channel Analog Audio to SD/HD-SDI with Embedded Audio
AJA HD10C2 $1190
AJA D/A Converter, 10-bit, SDI to Component or Composite Analog
Aja HI5 $495
HD-SDI to HDMI Mini Converter. Requires Additional Power Supply
each converter requires a $40 power supply.
here's a link to the AJA catalog:
http://aja.com/pdf/AJA_06Catalog_web.pdf
Terry Nixon is offline   Reply
