cpu power...p4 versus duo core at DVinfo.net
Old December 29th, 2006, 02:33 PM   #1
Are the 1.66 duo cores roughly equivalent to a p4 3.2 ghz in computer power? In a vegas enviroment.
Old December 29th, 2006, 05:13 PM   #2
Yes.
14s - Intel QX6700 4 cores @ 2.66ghz
SOURCE: John Cline @ http://www.sonymediasoftware.com/for...ssageID=496672
SOURCE2: JohnnyRoy @ http://www.sonymediasoftware.com/for...735&Replies=19
15s - Macpro 2X2.66ghz dual core Intel processors (Vegas 7; old result was 45s)
SOURCE: Charley Gallagher @ http://www.dvinfo.net/conf/showthread.php?t=78558
19s - Intel Core 2 Duo overclocked @ 3.56ghz (*overclocked systems should be tested for stability)
SOURCE: ro_max@http://www.sonymediasoftware....howMessage.asp?ForumID=4&MessageID=497038
27s - Overclocked Intel E6300 @ 2.33Ghz (266mhz FSB --> 333mhz, 2MB cache, 1.86ghz originally; V6d; V7b = 28s)
SOURCE: Guy Bruner @ http://www.sonymediasoftware.com/for...694&Replies=31
28s - Intel E6600 Core 2 Duo (Vegas 6d; 2.4ghz, 4MB cache)
SOURCE: Emailed submission.
34s - Intel E6300 Core 2 Duo (Vegas 6d; 35s in Vegas 7b)
39s - AMD X2 4600+
SOURCE: JohnnyRoy @ http://www.sonymediasoftware.com/for...3138&Replies=4
*39s/74s - AMD X2 4400+ (Toledo core, 2X2.2ghz, 2X1MB cache, no dual channel memory, Vegas 6.0b)
SOURCE: philfort@ http://www.sonymediasoftware.com/for...447&Replies=26
*39s - AMD X2 4400+ overclocked to 2420mhz
SOURCE: Jayster @ http://www.sonymediasoftware.com/for...5519&Replies=0
*40s/76s - AMD X2 4400+ (Toledo core, 2X2.2ghz, 2X1MB cache, no dual channel memory, Vegas 6.0b)
SOURCE: TheRhino@ http://www.sonymediasoftware.com/for...239&Replies=61
44s - Pentium D 3.0ghz
SOURCE: GMElliot @ http://www.sonymediasoftware.com/for...ssageID=454055
see also: http://www.sonymediasoftware.com/for...3138&Replies=8 (45s)
45s - Macpro 2X2.66ghz dual core Intel processors (Vegas 6)
47s - Core Duo 1.83Ghz (laptop)
SOURCE: FrigidNDEditing @ http://www.sonymediasoftware.com/for...7142&Replies=3
*75s - P4 3.6ghz overclocked from 3.0 Pentium. A new 5xx-series 3.6ghz should be as fast or slightly slower.
SOURCE: Stormcrow@ http://www.sonymediasoftware.com/for...239&Replies=57
78s- AMD64 3700+ (san diego core??? [2.2ghz, 1MB cache], vegas 6, dual channel RAM)
SOURCE: Charley Gallgher@ http://www.dvinfo.net/conf/showthrea...8&page=2&pp=15
*78s- P4 3.2 overclocked to 3.8ghz (Northwood core???, 800FSB [it's overclocked, so the FSB is actually higher])
SOURCE: jamcas@ http://www.sonymediasoftware.com/for...ssageID=256422
79s- AMD64 3400+ (unknown core, Vegas 6)
SOURCE: Charley Gallagher@ http://www.dvinfo.net/conf/showthrea...8&page=2&pp=15
89s- 3.0E Pentium Prescott (865 chipset, dual channel RAM, Vegas 5)
SOURCE: Glenn Chan@ http://www.sonymediasoftware.com/for...239&Replies=57
90s - 2.8ghz Pentium (Prescott)
SOURCE: TalawaMan@ http://www.sonymediasoftware.com/for...ssageID=262716
90s - Opteron 246 2.0ghz X 2 (dual channel memory, old 2004 core, *VEGAS 5*)
SOURCE: rohde@ http://www.sonymediasoftware.com/for...ssageID=256422
*Please keep in mind Vegas6 has optimizations for dual processors, while Vegas 5 does not.
93s - AMD64 3200+ (2004, so probably old core)
SOURCE: PH125@ http://mediasoftware.sonypictures.co...ssageID=256422
99s is Sid Phillip's report in the same thread.
95s - AMD64 3000+ (2.00ghz, 512kb cache, single channel, socket 754, 2004 core)
SOURCE: ibliss@ http://www.sonymediasoftware.com/for...ssageID=256422
114s - Pentium-M 1.7ghz laptop
SOURCE: The_Jeff@ http://www.sonymediasoftware.com/for...ssageID=262716
128s - Sempron 2400+ 1.4ghz (Palmero core, S754, 256KB cache)
SOURCE: Glenn Chan
Athlon XP: There are results if you look around. They aren't as fast as Pentiums or AMD64.
These results are for the original rendertest.veg, not the new one. You can download it from:
http://www.vasst.com/resource.aspx?i...c-a7f431ebd02d
Remember to set best rendering mode. The file --> render dialog will override other settings, so be sure to set best mode there.
Glenn Chan is offline   Reply
