Cineframe24 Looks good Useable or not? at DVinfo.net
Old December 20th, 2006, 09:23 PM   #1
FX1 Cineframe24 Looks good Useable or not?
Hello, I did some tests and I love the way the Cineframe24 looks!
I read 1 article saying that it cannot be used for a film transfer ,so it was no good in the long run! Is that true?
Im currently trying to get a good workflow for this Indi Film I am doing!
I am using HDR-fx1 captured to V7 then Dvfilm 60i to 24p so I can edit 24p,but Dvfilm is So SLOW it is killing me wish that I could skip the Dvfilm part ,I like the way the Cineframe24 looks can I use this setting at all? Need help from someone who knows!
Here is a WMV clipd 1440x1080 with cineframe24
http://www.mediamax.com/steve_houser/Hosted/1.wmv
Steven Lee Houser
http://vimeo.com/testwork
Steven Houser is offline   Reply With Quote
Old December 21st, 2006, 12:28 AM   #2
looks good steve who was filmin
Nate Fields is offline   Reply With Quote
Old December 21st, 2006, 03:48 AM   #3
if you want it to go to film then the frame rate needs to match.
cineframe 24 just gives you the LOOK of the movement by halving the resolution. it is still essentially interlaced footage.
Philip Bloom
Old December 21st, 2006, 04:01 AM   #4
Yea Steve, Phil got it. Since you're using DVFilm, I'm sure you would've read their specifications for film out. They did recommend against cineframe24 for film out.
Zulkifli Yusof is offline   Reply With Quote
Old December 21st, 2006, 10:26 AM   #5
Yea I know!
These were the answers I needed to here again! Its just that the cineframe24 looks so much more like film to me than Dvfilm final 24p and the time it takes!
So im guessing that I cant use cineframe24 and Dvfilm 60i to 24p to ensure that Film look?
Steven Lee Houser
Old December 22nd, 2006, 02:44 PM   #6
Steven,
I don't know if this would help, but I find that using Connect HD with Vegas 7 is the best way to work with the FX1's Cineframe24. It removes the funky parts. I tested straight Cineframe 24 on the Vegas timeline against Cineframe24 (imported with Connect HD) and the Connect HD avi was so much better. Much cleaner footage.
Like you, I hate added render times, so for my smaller short film projects I'm willing to lose some resolution (due to the Cineframe24) and use Connect HD to get a better 24 frame look. If you use DVFilm, I recommend you always shoot in 60i with the FX1, and deinterlace with DVFilm from there.
Robert Kirkpatrick is offline   Reply With Quote
Old December 22nd, 2006, 03:18 PM   #7
What is the Exact resolution Loss?
Does any one Know the Exact amount of Lost resolution lost by using cineframe24?
Under my name there is a link to full resolution shot with cineframe24 ,in the properties of that clip shows no loss of res still 1440x1080 and in the picture cannot see any loss! So what i am asking for is there any Known FACT chart showing that it looses resolution by how much or are we guestimating it does?
Any Factual Link would be very helpful to me and others that like the cineframe24 look....
Thx to all the Pro,s that Knows!
Steven Lee Houser
Old December 23rd, 2006, 11:05 AM   #8
Don't know if I can give you the answer to that, but these are the links I've used.
http://www.cineform.com/products/Son.../CineFrame.htm
http://www.adamwilt.com/HDV/cineframe.html
http://www.sundancemediagroup.com/tr...24_cadence.htm
http://www.dvfilm.com/fx1/index.htm
In fact, this VASST site was very helpful for me when I switched over to working with HDV:
http://www.vasst.com/?v=HDV/hdvportalnew.htm
In my rush of typing, I think I said loss of resolution, when I should have specified that some have said that the Cineframe24 loses vertical sharpness. Some people have said that it's better to use DVfilm (converting 60i to 24p) over Cineframe Connect HD (converting Cineframe24 to 24) -- but I haven't done any tests on that to see which I liked better. I like the Connect HD workflow though.
Hope that helps.
Old December 23rd, 2006, 11:30 AM   #9
Great Links Thx Robert!
I actualy know the the Facts With Dvfilm FilmHouse..For Transfer to 35mm Film or 70mm Film:
NO CINEFRAME24 No CF24 CF30!!!
It just Looks so dam good! But will not be Transferable In the Correct way!
I will Have to gain That Film Look by other Means Lighting DOF and CC!
Thats all I have Left!
Thx for replying again Robert! Happy Holidays!
Steven Lee Houser
