Posts: n/a
My new LaCie D2
I just brought this external hard drive and I am trying too take all the stuff i need from my Laptop PC and move it to my new Mac book pro. But after installing the driver, I can't get the drive to appear on the My Computer menu. It has installed because it appears on the device manager section, but i can't do anything with the drive from here.
When I put it into the Mac it appears on the desktop straight away so it can't be the drive. I know the mac and pc require different formats, but i need to get the drive up in My Computer so I can format it to a PC and Mac friendly format. Please Please Please help, I have kicked everything around the house and I'm so annoyed. Cheers |
hmmm... try turning computer on first, without having hard drive plugged into laptop, and keep hard drive powered off....
then power up hard drive, give it a sec, and plug into (firewire or USB) on the Macbook. that worked for me on a HD that i formatted on another computer. |
G'day Ben,
You should be able format the drive as FAT32 under OS X. I can't remember the exact process, but you can use the disk utility to do it (/Applications/Utilities). A breif warning on FAT32. While both OS X and Windows (and just about anything else) will read it happily, it does have a 4GB file size limit. So if you are planning on storing files that big (or bigger) on there, you'll need something else. |
#4 | |
Also, I just found the following: http://www.appleswitcher.com/viewtopic.php?t=12670 Someone there is attempting to do the same thing. |
